Old 07-19-2011, 03:41 PM   #1
Slidout toppers
My question is I want to install your slide out cover on a 2012 Rockwood 8312ss on two slideouts. The instruction say to place the mounting brackect 5 to 6 inches down from the top rail. My slideout has a rubber frame on the outside that is right in the way. If I drop the bracket down under the frame so it can sit flush on the wall it is 7 to 8 inches down from the rail. Will this work? The rail is already attached from the factory so I am not using the rail that came with cover. Thanks for your help.
phinski is offline   Reply With Quote
Old 07-19-2011, 04:15 PM   #2
DAISY BOYKIN's Avatar
Maybe this will---------
Maybe this will answer your question. I used stainless screws in lew of the ones that came with the toppers.
ID:	6904   Click image for larger version
ID:	6905   Click image for larger version
ID:	6906   Click image for larger version
ID:	6907   Click image for larger version
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-20-2011, 05:40 AM   #3
Thanks The pictures are just what I need to see.
