Old 10-31-2015, 07:59 PM   #1
Cindimac's Avatar
Small air compressor to blow out lines to winterize
Looking for an air compressor any suggestions? Thanks and happy holloweenie everyone....
Cindi Mac
Cindimac is offline   Reply With Quote
Old 10-31-2015, 08:05 PM   #2
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
I got this one from HF - 3 gal. 1/3 HP 100 PSI Oilless Pancake Air Compressor
Very lightweight, plenty of power to blow out the water lines and it's got enough power to bring my rear tires up to 80psi (takes a little while, but not really an issue).
It's small and light enough that I carry it in the motorhome's storage compartment.
If you look for HF coupons you can buy it for $39, or if you have a 20% off coupon you can get it for around $47.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 10-31-2015, 08:07 PM   #3
My small compressor is my small shop-vac that has both suck and blow. In fact I use it to blow out the through hull valves on my cruiser. For both the cruiser and the camper I use the suction to clear the lines after draining with the low points open.
Timtation is offline   Reply With Quote
Old 10-31-2015, 08:43 PM   #4
Marksha83's Avatar
Just got this at Menards for $99. Fills tires great, small, portable and can be used to winterize.
2014 Forest River Georgetown 335
SOLD: 2016 Coachmen Leprechaun 319DS Ford E450 Chassis Triton V10
Marksha83 is offline   Reply With Quote
Old 10-31-2015, 09:04 PM   #5
Ford Idaho's Avatar
On sale it was under 60 bucks with all the extras.
Old 11-01-2015, 08:16 AM   #6
Sallen80's Avatar
Where did you get that?
Sallen80 is offline   Reply With Quote
Old 11-01-2015, 08:19 AM   #7
You don't need a great big industrial model...between 3-5 gal is more than enough as it will give you upwards of 100 psi. For winterizing your plumbing I read somewhere and do it myself that max through the plumbing is 50 PSI and max for my tires is also 50 psi. I have a knob on mine for setting the psi limits. I got mine at Canadian Tire which makes it a Mastercraft Product for I think it was $75. but I bet if you change the paint from blue to red or green and stencil another name on it, it will work just the same.
Kevin
2009 F150 XLT crewcab 5.4L and 3.73
2010 Flagstaff 27 BHSS
tenttotrailer is offline   Reply With Quote
Old 11-01-2015, 08:21 AM   #8
Cindimac's Avatar
Thank you all for your information , found a coupon for HF, so off to buy one today..Hope everyone changed there clocks today!!!!!😈
Cindi Mac
Old 11-01-2015, 08:22 AM   #9
hrlyguy2's Avatar
Harbor freight has a ton on sale.
I got a small oil less air brushing compressor 30.00
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 11-01-2015, 08:24 AM   #10
Ford Idaho's Avatar
Sears.
winter, winterize
