Old 05-06-2016, 12:08 PM   #11
When we were in Yellowstone I brought a 600 watt generator and a small Schumacher battery charger. I connected the charger to the battery and plugged the charger to the generator. Worked great.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 05-06-2016, 01:22 PM   #12
Moderators' Assistant
bikendan's Avatar
Originally Posted by Tomgky View Post
Thanks everyone for all the info. I never thought about the noise level. I may look into the Champion 2000i
Yep at 91db, the Rangers will hear it in the next campground!
I've never heard of any small generator THAT loud.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 05-06-2016, 01:47 PM   #13
Butch Wilson's Avatar
It is a 2 cycle generator, that could be why it is 91 db .
Butch Wilson is offline   Reply With Quote
Old 05-06-2016, 01:48 PM   #14
TGR
TGR's Avatar
Recharging a battery takes time but frugal power usage and 2-3 hours of recharge time per day will keep things running. I wasn’t able to find any manufacturer’s data on charge times for the WFCO converters but Progressive Dynamics has a couple of FAQs on this issue. According to PD:
11. How long will it take to re-charge my RV battery?
Battery recharge time is controlled by many factors, such as battery size, converter output rating the number of 12-volt lights and appliances that are “ON” during the re-charge cycle and how far the battery has been discharged. In our testing a 125-AH (Amp Hour) battery was fully discharged to 10.5-volts and then connected to a PD9160 (60-Amp) Converter/Charger set to our standard output voltage of 13.6-volts. The battery reached full charge in 70-hours.
12. I dry camp most of the time and want to recharge my RV batteries using my generator the next day. Is there any way I can get a faster recharge rate?
Yes, all 9100 Series Converter/Chargers are equipped with our TCMS (Total Charge Management System) Connector to allow you to easily install our Charge Wizard. All 9200 Series Converter/Chargers are equipped with the TCMS / Charge Wizard built in. The Charge Wizard senses that your batteries are low and that you want to charge them fast therefore, it automatically increases the output voltage of the Converter/Charger to 14.4-volts and will return a 125-AH battery to 90% of full charge in 2-3 hours. Full charge is achieved in approximately 15 hours.
A small generator powering your converter will overload if the batteries are too depleted. You could pair a small generator with an external battery charger that had a limited charging capacity. However, that will greatly extend your required charge time.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 05-06-2016, 05:10 PM   #15
V-Lite Fun's Avatar
Northern Tool has a 2000W Powerhorse generator for under $600. It is quiet like a Honda and weighs just 45 pounds. I have one. To charge your battery with it use a battery charger plugged directly into the generator to the battery. It will charge much faster than going through the trailer.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 05-06-2016, 08:23 PM   #16
We will be camping in Yellow Stone this summer for a week in a campground with no hook ups. I'm looking at a small Storm Cat generator at Harbor Freight that has a 800 watt out put. Can anyone tell me if this will charge my two size 24 batteries. I don't need it to do anything else. I like the size of it and the weight. Thanks in advance for any input you may have.
Yikes. We used to have one of those. They are very loud, very weak and no support is available. We gave ours away and bought a Yamaha 2000is.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 05-06-2016, 08:35 PM   #17
Jimsue's Avatar
" To charge your battery with it use a battery charger plugged directly into the generator to the battery. It will charge much faster than going through the trailer."
Why would that be the case? Just curious...
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 05-06-2016, 09:01 PM   #18
Flybob's Avatar
The best method of charging the battery with a generator is to connect the TT to the generator and allow the converter to charge the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 05-06-2016, 09:10 PM   #19
That is not totally accurate.
If you have a 3 stage 55 amp converter and a 3 stage 55 amp charger then that statement would maybe be accurate (charger would be a bit faster). The reason being that the converter would have a small 1-2 amp extra draw (CO detector/propane detector etc) beside charging the battery.
If you have a 3 stage 55 amp converter and a 3 stage 15 amp charger then the converter will charge the battery much quicker.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 05-06-2016, 09:13 PM   #20
dcheatwood's Avatar
Plug a regular 12v battery charger into the gen and it'll charge it faster. A 15amp will work.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
generator, battery
