Old 08-30-2016, 01:53 PM   #21
Originally Posted by randman132 View Post
That totally sucks. Make sure you redo the bearings after that too. Common maintence for a boat trailer.
It has bearing buddies I just installed a week ago, so I should be ok.
lugoismad is offline   Reply With Quote
Old 08-31-2016, 08:15 AM   #22
Wolverine 1945's Avatar
Not so sure about that ???
If it were me I would probably pull the wheels and repack the bearings !!!
And check the brakes,,, Just to be sure !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-17-2016, 10:34 AM   #23
RSchleder's Avatar
Bearing Buddies are the last thing I'd use even when normally greasing my wheel bearings. I used them 1 time and followed the defined process to the letter. Yes, jacked each wheel up and slowly turned while carefully/slowly squeezing grease into the zerk. 2 wheels didn't have grease come out the front so figured I'd find grease all over the brakes and sure enough, when disassembled, greasy brakes. Now I'm back to my method of 30 years, pull wheels and hand pack each bearing!!!!!
Days camping (2016)----181 days
Days camping (2017) --- 14 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
boat
