Old 05-22-2018, 02:48 PM   #1
So much to learn
I replaced the class C Forester with a class A Mirada. I was told that, while driving, I can run the generator and use the roof A/C for more efficient cooling and better fuel efficiency.
Any knowledge on this subject is extremely appreciated.
MargiLou is offline   Reply With Quote
Old 05-22-2018, 03:46 PM   #2
Probably more cooling simply but don't know about the fuel efficiency.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 05-22-2018, 03:57 PM   #3
So, is it OK to run the generator and the engine at the same time? And NEVER the generator while connected to shore power?
Old 05-22-2018, 04:00 PM   #4
Director, FROG
F.R.O.G.'s Avatar
Yes, you can run the generator and run your house AC while traveling. If you shut off the dash AC you'll use slightly less fuel for the engine. However, you'll be using fuel for the generator, somewhere around 1/2 gallon per hour depending on the load.
If you drive 60 mph and get 10 mpg (just for easy calculation), you're using six gallons per hour. If you cut your engine fuel usage by 10% (and you probably won't), you're saving 6/10 of a gallon per hour, about the same as what you're burning in the generator, so the fuel is pretty much of a wash.
Keep in mind that the generator probably requires service after about every 150 hours of use, so you're going to be increasing the maintenance cost for the generator.
You'll have to decide if the perceived savings and comfort are worth it to you.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
