Old 06-20-2015, 10:11 AM   #1
wyo700's Avatar
Solar panel and power
Is it ok to have a solar panel and power connected to my camper while I am away from it for a week in the event the power may go out. I will be leaving the propane on so the fridge will stay on no matter what happens but would like the batteries to stay charged as I will be taking my camper to a different location next weekend. What does everyone think. Thanks.
2012 Sandstorm 203SLC
2013 Toyota Tundra Crewmax 5.7
2014 Honda Pioneer 700-4
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 06-20-2015, 11:50 AM   #2
mud yapster's Avatar
I have 520 watts of solar changing my 435ah battery bank with a charge controller and I have my RV plugged in to the power pole. The solar just keeps the batteries charged plugging into shore power doesn't bother anything. The converter also can charge your batteries when plugged into shore power at the same time your solar is charging. Use a charge controller from your solar panels so your battery bank don't get over charged. If you loose shore power the solar panels will keep your batteries charged.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 06-21-2015, 10:26 AM   #3
wyo700's Avatar
Ok thank you. I do have a sun saver connected between the batteries and solar panel so I'm good there. I figured I was fine but wanted to double check.
2013 Toyota Tundra
power, solar
