Old 03-18-2012, 09:03 PM   #1
Athens-M50's Avatar
Spaire Tire bike rack?
Is anyone using one of these???...
Amazon.com: Allen Deluxe 3-Bike Spare Tire Mount Rack: Sports & Outdoors
Need to haul 3 bikes.....always too much crap in the bed......hitch is full
thought about putting on on the front of the truck?......anyone doing that???
But what about the license plate???.....worried about being pulled over because the tag is covered up?
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 03-18-2012, 09:13 PM   #2
Dave_Monica's Avatar
If you do, you'll probably be losing your rear bumper, spare tire, bikes and bike rack on route.
The 4" steel bumper is only 0.080 thick welded on the ends of the frame rails. The bumper will fail at the welds if you hang too much weight off the spare tire.
Dave
Old 03-18-2012, 09:21 PM   #3
Athens-M50's Avatar
hummmm....good point
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-18-2012, 09:52 PM   #4
Triguy's Avatar
X2
Athens, unless Shamrock used much sturdier frames and bumpers in 2002, than you are out of luck.
We've all considered it and its a busy topic on the forum. Conclusion is its a bad idea.
A hitch mounted to the front of your truck is a better alternative.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-18-2012, 09:58 PM   #5
FWIW, I moved the spare tire and carrier from the rear bumper and made a mount for it in the front of our 5th wheel basement. I made a mount that bolts onto the rear bumber and carries two bikes. The rack and bikes weigh 90 lbs, the spare tire and carrier were 65 lbs, so only 25 lb more weight on the bumper. I check the bumper mounting welds every trip...all is good after 2 years use.
Dave
Old 03-18-2012, 10:04 PM   #6
Herk7769's Avatar
Been there done that.
Tried them all and now the bikes ride inside the camper again.
I never have to worry about getting to the campground and finding my bikes; spare tire; and bumper are on the interstate somewhere.
The cracked weld shots are not mine; but they could have been.
When I used the spare tire mount bike carrier I could not keep the end caps on. The bumper twisted so much it was popping them out.
ID:	10993   Click image for larger version
ID:	10994   Click image for larger version
ID:	10995   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 03-19-2012, 02:18 AM   #7
bikendan's Avatar
yea, Athens, you don't want a bike rack on the bumper, let alone the flimsy spare tire bracket.
you'll be watching the bikes, the rack and the tire bouncing down the road, in your rear view mirror.
your Shamrock has an ultra-light frame and only by having a welding shop weld and brace a receiver to the frame and bumper, can it support a bike rack with bikes on it.
for newer trailers, this mod would void the warranty but since yours is out of warranty, you don't have to worry about that.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-19-2012, 05:24 AM   #8
Mountainmanbob's Avatar
front plate covered
after reading much here
seems to be your best bet
the police usually don't bother campers traveling
that have the front plate covered with bikes
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-19-2012, 07:49 AM   #9
Herk7769's Avatar
As you can see from my "front mount" bike hitch, they do not block the headlights.
However, they DO move around a lot up there and my hood took a beating from the handle bars. No amount of tying it down and jamming stuff in the hitch mount would stop it from doing so. Every wind gust on the freeway lifted the whole assembly and "flew" it into the hood.
The hitch itself is low to the ground reducing your ground clearance. Even with the bike mount off, I was hitting parking lot concrete bumper stops routinely. With it on, you run the risk of damage just going out to dinner.
Every time you move the camper the bike hitch had to go on; bikes loaded; everything tied down; get where you are going and take everything off if you want to go out to eat. PITA
However, of all the other choices for ultra-lite campers it is the best "outside" option.
Old 03-19-2012, 08:15 AM   #10
Rugged Brown's Avatar
Those pics of the broken weld belong to me. That happened with just the weight of the spare tire. As I stated in an earlier post when I posted thoses pics, I did carry a couple of bikes for a couple of short trips. I removed them because of the damage done to the frame on the rear window, not because of the bumper strength. The welds broke long after I removed the bike rack. Bottom line is, those bumpers are not meant to carry the weight of a spare tire, let alone bikes. I only wish that the manufacturer can build a rearing bumper that can withstand the weight of a couple of bikes and still remain a "light weight" camper/fiver.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
bike, bike rack
