Old 09-12-2016, 01:53 PM   #21
Talked to Wayne Biglow he said my trailer is to old to help me out. And asked me why did I not contact him when trailer was under warranty. I told him this just happen my trailer has no leaks. I like this trailer a lot however I'm beginning to wonder if I trust Forest River
Lookng4us is offline   Reply With Quote
Old 09-12-2016, 01:54 PM   #22
Sorry I talked to Wayne Bigler
Old 09-12-2016, 01:58 PM   #23
I have also talked to Chuck Patterson
Old 09-12-2016, 02:52 PM   #24
trudinator's Avatar
Looking4us do you want my contact? Deb Rimsa was amazing to work with. And SHE is the warranty person for Rockwood.
2012 Rockwood 8293RKSS
trudinator is online now   Reply With Quote
Old 09-12-2016, 03:55 PM   #25
I think this is going to be something I fix @!$++
Old 09-14-2016, 07:02 PM   #26
dea49's Avatar
Originally Posted by Lookng4us View Post
If it works please let me know. And how you did it
Well I finished with the painting of the hallway, reinstalling the refrigerator so I thought I'd attack the weak spot in the floor.
First I removed the toilet thinking it might be leaking but it wasn't. Then I thought I could force a rigid tube in between the luan and styrofoam to inject the expansion foam but there wasn't enough leverage to control it's direction. So I just cut a small hole in the vinyl to see if it was poor workmanship or rotted wood. It was rotted wood and to make matters worse, black mold.
At this time I decided I needed to get on with the big fix so I cut away the hallway vinyl. I appears that the damage is centered around black water tank vent for about 3 feet. Looks like maybe at one time water was coming from the roof on the outside of the pipe and was able to get under the vinyl. When I had purchased the camper the vent caps were in bad shape.
Good news is the damage was dry so I will remediate the mold, remove the rotted luan, replace it and all the vinyl in the camper. This will however cause me to remove the carpet in the bedroom and replace it as well.
I will keep you appraised.
2007 Rockwood UltraLite 2603
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
dea49 is offline   Reply With Quote
Old 09-14-2016, 07:34 PM   #27
Chuck
Kitchen and bathroom......look for leaks. Water damage will cause that.
Idaho_Chuck is offline   Reply With Quote
Old 09-14-2016, 08:39 PM   #28
dea49's Avatar
We have had a lot of rain lately including a hurricane and it is completely dry so I believe the damage was caused by an earlier leak probably around the vent pipe. You can almost see the concentric rings evenly going away from the pipe caused by each leak soaking further and further.
Since the damage is around the inside wall where the vent pipe is and away from all the toilet and sink connections I do not think those are the sources of the original leak.
Thank you for your input.
Old 09-15-2016, 12:04 PM   #29
dea49's Avatar
In the middle of remediation. The mold spread isn't as bad as initially thought. It extends about 18" around the vent pipe.
I did notice that the bleach foamed when applied so that means there is urine in the luan. I don't get it at the toilet hole so I think it must be coming from a crack or bad fitting on the vent pipe connection to the black tank.
QUESTION: Before I rip the wall out, does anyone know if the vent pipe is screwed or glued to the black tank?
Old 09-15-2016, 12:46 PM   #30
trudinator's Avatar
I'd contact someone at Forest River. They could answer that question in a heartbeat
