Old 04-10-2016, 07:58 AM   #1
Quick question does everyone's stabilizers work loose? Any suggestions appreciated.
Shagginwaggin0389 is offline   Reply With Quote
Old 04-10-2016, 08:14 AM   #2
I am not sure what you mean by work loose? I know after setting up I have had mine sink into the ground a bit so they need to be retightened after the first night.
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-10-2016, 08:15 AM   #3
Professional Curmudgeon
Apparently yours did, so "no" would be the incorrect answer.
You could use nyloc nuts or thread lock on the mounting bolts.
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
Reese dual cam SC/WDH
wrvond is offline   Reply With Quote
Old 04-10-2016, 08:22 AM   #4
nomad297's Avatar
I used to have some scissor-type stabilizers and they would work loose from the movement in the trailer. When I would deploy them, I would sometimes get them to just where I wanted them and take the tool off and watch the worm screw start turning backwards. I stripped them of all oil and grease and that solved the problem.
Old 04-10-2016, 08:30 AM   #5
Thanks Nomad297 that's exactly what's happening.
