Old 10-05-2009, 05:30 PM   #1
Gunnarts's Avatar
Question Steadyfast or JT's Strong Arm Trailer Stabilizer
[url]http://www.steadyfast.com/
[url]http://www.jtrv.com/index.html
Has anyone had experience with either of these products? We are picking up our new trailer next Tuesday. The one thing I can't handle is a shacking vibrating trailer. I want to know how easy these are to install and how effective they are to use!
Gunnarts is offline   Reply With Quote
Old 10-05-2009, 09:11 PM   #2
pokyjoe48's Avatar
Send a message via AIM to pokyjoe48 Send a message via MSN to pokyjoe48 Send a message via Yahoo to pokyjoe48
Smile
Hi Gunnarts, We put "JT stabilizers" on our Cardinal 29ts 5th wheel and we're really happy with them. I put them on all four corners and they stay right on the landing legs. All you do is loosen the hand screws and lower or raise the landing gear then tighten them up and no wiggle. I also recommend these for travel trailers. I haven't seen "Steadyfast" but I.m sure they're on the same line. It makes me wonder when I see all these travel trailers and 5th wheel trailers without these I wonder how uncomfortable it must be inside but I guess after a few cocktails and a long day of to much fun you really don't notice that much. I've seen all kinds of blocks and screw jacks to try to steady trailers but wow that's a lot stuff and work you have to go thru. It will be a good investment and you'll enjoy your adventures with a bit more comfort.
pokyjoe48 is offline   Reply With Quote
Old 10-05-2009, 10:10 PM   #3
I had put an extra set of jacks on our tt and it helped a little, when we ordered our 5er we ordered jt stabilizers on it. We used it for the first time this weekend and could tell a big difference. when we use it more i can tell you more. Hope this helps
jim&dianne73 is offline   Reply With Quote
