Old 07-05-2015, 06:13 PM   #1
Steering pull
Hey all!
When pulling my 33 ft tt with my 2015 f250 gasoline, a lot of the time I notice that I have to turn the steering wheel to the right so that it's not straight, but we are driving straight. Does that make sense?
What's up? I had the truck alignment checked and it's good.
Also, I have a bulldog hitch setup with 2 sway bars and I'm on the 3rd or 4th link down from the top on the other bars.
Karl
karlrmac is offline   Reply With Quote
Old 07-12-2015, 11:42 AM   #2
Tater70's Avatar
This could be several things. When I had my TT I had a simular issue and found that adding airbags to level the TV seemed to help. Taking weight off the front will make your truck drive entirely different then when the weight is even. I used both weight distribution hitch and adjusting air pressure to find a good ride and straighten my wheel.
Tater70 is offline   Reply With Quote
Old 07-12-2015, 12:12 PM   #3
lesptr's Avatar
I've noticed that with my f350 and wdh that if my last tight turn was to the right, my steering wheel will be off centered to the left when going straight. If the last tight turn was to the left, steering wheel will be canted right when going straight, but to a lesser degree. It was like this with the f150 as well. I often wonder if it's normal.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
