SOLVED...... Contractors Solvent
Went to Ace Hardware and browsed the solvent isle.
Came across an item like Goo Gone except it is called Contractors Solvent. A Orange cleaner.
Takes tar, adhesives, caulking, etc out of clothes, off walls, good on carpet, metal, wood, plastic, etc...
I bought the bottle, 10 bucks.
Sprayed it on the area to be cleaned and let it set a few minutes as per the instructions. Had an old t-shirt as a rag.
Wiped the area and the SticknBond adhesive came right off the carpet. The little bits that were embedded deeper pulled off the carper also.
Had a spot that had some tar or asphalt on it, about the size of a dime. Sprayed it and it came right off.
This stuff works and it did not get deep to mess the adhesive backing to the carpet. It does warn on the bottle you have to be careful when cleaning carpet with the product.
TV 2012 Chevrolet Silverado CC 5.3
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
