Old 12-12-2010, 08:05 PM   #11
Infractee
Originally Posted by crocus View Post
I don't think it's all that unusual, as I've seen more than a few similar twisted wrecks, all jacknife/spinout situations. Number one reason why we tow a fifth.
Crocus, I have enjoyed many of your post and the useful info you have shared but I must say, the above comment is most callous and unwarranted at this time.
The man is on here telling his story of a terrible accident which easily could have been tragic, and you feel the need to point out to the OP and whoever else may be reading, that it is quite obvious, that anybody who has a tongue pull trailer is skirting a fiery death everytime they pull a TT and only people wise enough to know how to cheat the grim reaper own a fifth wheel.
Please dont make me do a google image search of fifth wheel TT accident pictures, I am sure the results will be plentifull...
And even worse, pictures of wrecked 18 wheelers, or 18 wheelers experiencing sway going down the highway, the original fifth wheel.
RhoZeta is offline   Reply With Quote
Old 12-12-2010, 09:52 PM   #12
Just being honest. I realise some don't like honesty, but that's life.
Didn't mean to be callous, though. I know how scary such a situation could be. I've been in a couple of panic situations with our fifth wheels, and it ain't no fun, but have never even come close to losing control.
Old 12-12-2010, 10:14 PM   #13
bikendan's Avatar
Originally Posted by DocWisconsin View Post
What hitch were you using to haul your the 183?
i'd also be interested in what WDH you were using. and what do you mean you didn't have time to reach for the TT brakes?
Old 12-12-2010, 10:26 PM   #14
Campster's Avatar
Scary situation. I believe when he said he didn't have time to reach for the TT brakes he meant reach for the brake controller to apply only the brakes to the TT to stop the swaying. That would be my guess.
Campster is offline   Reply With Quote
Old 12-12-2010, 11:16 PM   #15
5th Wheel Trailers are not immune to sway, and anybody that thinks they are are kidding themselves and those around them. Enuff said.
Glad no one was hurt.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-13-2010, 06:33 AM   #16
samsc03's Avatar
I was not using a WDH or sway bars as we never needed ones. Towed at that speed before in worse wind and never had any excessive sway or handling problems. Also the rear springs are 9 pack lift springs so the bed never sags and the tires are load range E so we were equipped well. The tire pressure may have caused the same result even with a special hitch. Yes I meant I was reaching for the brake on TT brake controller.
And the for the fifth wheel guy, I was not gonna reply to that because I figure the rest would have noticed that was a little harsh. Not to mention there was a fifth that passed us just after the wreck and I was hoping he would stop and give my girl somewhere warm to sit. He did not. Make friends and loose friends on the highways.
2011 Shamrock 19
2003 Toyota Tacoma V6 4wd
Tekonsha Voyager
Equal-I-zer
samsc03 is offline   Reply With Quote
Old 12-13-2010, 07:41 AM   #17
"I was not using a WDH or sway bars as we never needed ones. Towed at that speed before in worse wind and never had any excessive sway or handling problems. Also the rear springs are 9 pack lift springs so the bed never sags and the tires are load range E so we were equipped well. The tire pressure may have caused the same result even with a special hitch. Yes I meant I was reaching for the brake on TT brake controller"
That explains why you lost control. You never need sway bars, until YOU NEED THEM. And your brakes should be set up so the trailer always comes on harder than the TV, thus assuring it is available in a panic situation. When the chit hits the fan, you ain't got time to be reaching for the brake controller, and that is dangerous in itself, as your attention should be on driving.
Sorry to be harsh again, but it appears you may have been an accident waiting to happen.
Old 12-13-2010, 08:09 AM   #18
Herk7769's Avatar
I also am quite thankful there were no significant injuries. I would like to caution you, however, to be alert for Post Traumatic Stress Syndrome. Anytime a person is subjected to rapid onset stressful conditions that are potentially life threatening, delayed reaction (physically and mentally) is almost guaranteed.
As to 5th wheel sway, I must say that an improperly loaded 5th wheel (one with a pin weight outside the safe range of 15% -25% of total camper weight) is a squirrely handful and operation at the extreme ends is very hard on the truck as well. Overly light pin loads (most common way of dealing with an overloaded TV) causes tail wagging that causes steering tire wear at many times the rate of drive wheels. (Don't ask me how I know )
HAM CALLSIGN - KC3FFW
Old 12-13-2010, 11:05 AM   #19
Sorry to hear of your unfortunate accident. Thank the good Lord you all were okay. One thing I couldn't help noticing was that it appears your towing vehicle was a Tacoma, if I read correctly. While it may not have made any difference in the accident, I just feel myself that the truck is a bit small-ish for a towing vehicle- sort of like towing with a Colorado/S-10, or a Ranger. I also would be sure X2 to use a sway reducing hitch next time. You may feel it isn't necessary, BUT when you need it.....nuff said. Again, sorry for your loss, and best of luck in the future! Randy
Old 12-13-2010, 11:53 AM   #20
samsc03's Avatar
Just heard from the insurance people that we have the necessary replacement insurance so that is very good news. Oh yeah, without a doubt I will do it with a sway hitch and WD next time. I don't think it would have stopped this though. I was still losing pressure. The object was just removed from the tire was real nasty,left a big hole going in and was losing fast so at speed and while towing I imagine it dropped quick once we picked it up.
I can understand everyone thinks the Tacoma is small to do the job. It did it well as it could under the circumstances. My girl said I saved us controlling the spin but I credit it to the truck staying upright which is impressive. Also the front springs are 950lb coils and rear shocks are remote reservoir dual bypass shocks.
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
