Old 03-01-2015, 01:26 PM   #1
Storage at home, uneven ground
We recently purchased a Freelander 27QB and will be picking it up in Alvarado in a couple weeks. Now that we've actually pulled the trigger we are looking at the space on the side of the house and we have overlooked the fact that there is maybe a 4' drop from one end of the space to the other, the space itself exceeding the dimensions of the RV by 4.5' in length and 5' in width.
I've made a mockup to make sure I can squeeze it in the space, but I'm a little anxious about the level change. How would you suggest I compensate for this for both short term (in between trips) and long term (winter) storage times? Is it ok to store an RV unlevel over the 3-4 months of winter? What should I use to keep my 12k lb. RV secure from rolling down such a grade?
Thanks.
Wenatchee Willie is offline   Reply With Quote
Old 03-01-2015, 01:36 PM   #2
Platokidd's Avatar
I would store it fairly level. Side to side / One option is to build a pad to level things out. You could use some 2x12's to drive up on.
Front to back I would get some good wheel chocks .
A 4 foot drop is a lot to compensate for. Can you level the terrain any in that area?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-01-2015, 01:37 PM   #3
davel1971's Avatar
that seems like an awfully steep slope to safely park it on. 4ft in 27 feet is very steep
David & Lynn
Old 03-01-2015, 01:44 PM   #4
Ashley's Avatar
That's what I was thinking. I was hoping he had a typo and meant Four Inches, but I'm afraid I was just being hopeful.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 03-01-2015, 01:49 PM   #5
davel1971's Avatar
I read it a few times wondering the same, but figured 4 inches wouldn't be worth mentioning. Many campsites aren't that level
David & Lynn
Old 03-01-2015, 01:50 PM   #6
If it has one and you plan on having the fridge running while its parked there, thats way too steep. Even just the parking of it is a little steep make sure wheels are chocked.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-01-2015, 01:53 PM   #7
Not really a typo, more a miscalculation.
Just went out and used my Walking Vertical Dimension Indicator (aka: wife) to take a more discerning estimation.
There's actually only about a 1 foot drop from the back to the front.
Fridge would not be running while it is parked in this location.
'15 Freelander 27QB E350
Old 03-01-2015, 01:58 PM   #8
Platokidd's Avatar
Much gooder Now the 2x12 will be a more viable option with chocks.
nights of camping
Seasonal
Old 03-01-2015, 02:02 PM   #9
davel1971's Avatar
that's not so bad. Just make sure it's securely chocked BEFORE unhooking from truck.
David & Lynn
Old 03-01-2015, 02:04 PM   #10
Platokidd's Avatar
its a class C
nights of camping
Seasonal
storage
