Old 12-23-2016, 08:18 PM   #1
cburchel's Avatar
Storage in the pass thru
Has anyone made like a tray of some sort that uses the aluminum frame structure in the pass thru. Trying to get some ideas. When we get our 2017 Salem hemisphere 29bh back from the dealer I'm going to try and come up with something. Mainly going to use it to store some wood blocks and such.
2006 Chevrolet 2500 Duramax with some added power / 2017 Salem Hemisphere 29BHHL
cburchel is offline   Reply With Quote
Old 12-23-2016, 09:32 PM   #2
If you don't want to use up your belly storage, you may want to look at something like this.
Underchassis Storage Container, Double Without Spare Tire Carrier, 96” - See more at: Underchassis Storage Container, Double Without Spare Tire Carrier, 96” - Lippert Components Inc 175180 - Storage Accessories - Camping World
wildcatter is offline   Reply With Quote
Old 12-25-2016, 10:13 AM   #3
MrNiceGuy's Avatar
Here are some ideas.
http://pin.it/WpxEJvd
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 12-28-2016, 10:02 AM   #4
I built one out of wood, but you could easily make the frame out of aluminum angle or square tubing.
And here are the plans.
Gotta go campin!
Old 12-28-2016, 10:05 AM   #5
cburchel's Avatar
Thanks for the ideas. I really need to get my camper back so I can get to work.
Old 12-28-2016, 02:21 PM   #6
I have a black fibre glass unit that extends from side to side equipped with two bins about 14" high....Just pull each out from either side..Very handy!!!!!Had it in my 2 TT's and moved it to my 5er...J
Jim in Halifax is offline   Reply With Quote
Old 12-28-2016, 02:39 PM   #7
We use two 36" long "underbed" plastic storage bins without the covers. Fits drill for level jacks, blocks, hoses, parts from tow hitch, etc...
As long as you do not "throw" things into the bins to crack them they are great and cheap. See link below for a sample of such bins:
https://www.amazon.com/Hefty-Under-S...1KG6HYKJDVB3Q5
2016 Dodge RAM 3.0 Eco-diesel
2016 Rockwood Ultra-lite 2304DS
mckittrick5791 is offline   Reply With Quote
Old 12-28-2016, 02:51 PM   #8
I mounted some wire shelving to the front wall of the pass through on mine.
I bolted rails to the wall on both sides (pass through & front compartment) and mounted the wire rack shelving upside down on the brackets so it made a lip to hold stuff. Now I have shelves in both compartments.
ID:	127247   Click image for larger version
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 12-28-2016, 03:31 PM   #9
Question Details about your shelving
I am a new coach owner and I saw your post. What did you bolt your shelf into? I am afraid I would hit something important. Do you have more pictures up close so that I can see details more clearly? I appreciate any help. I have tons of room, but it is really wasted without some type of shelving in place.
Thank you,
Carolyn
topdoggette is offline   Reply With Quote
Old 12-28-2016, 04:24 PM   #10
Thank you,
Carolyn
Hi Carolyn,
My unit is a 5th wheel. It has a wall between the inside storage pass through and the front compartment. (under the overhang)
Being in my basement area, there was nothing of importance inside this particular wall. Simply structural.
There's no plumbing or wiring within this wall on mine.
I basically sandwiched the wall between the rails (rails on both sides of the wall) and used through bolts w/nuts to fasten them. (a bolt through the rail, through the wall and through the rail on the other side with a nut) Then I mounted the braces and shelving on them just like you would in a closet in the house. With the exception (as I noted earlier) I mounted the wire shelving upside down so there would be something to keep the stuff from falling off the shelves.
I would guess that maybe you have a couple of walls in the basement of your coach that are common to two storage areas where you could possibly do the same thing. Certainly if you believe there is something of importance in there, check first!
Old 12-28-2016, 04:39 PM   #11
Over the past 3 yrs, I have made several for different folks using garage door rails anchored to the basement floor. I made mine where the front half of the door hinges down for easier access. I also made Witch Doctor a slide out shelf using the same principle.
Name:	Basement drawer tethered out the curb side 1.JPG
ID:	127260   Click image for larger version
ID:	127261   Click image for larger version
ID:	127262   Click image for larger version
Name:	Basement drawer out as far as it will go driver side.JPG
ID:	127263   Click image for larger version
Name:	Basement drawer tethered out the driver side 1.JPG
Name:	slider rack 015.JPG
Old 12-29-2016, 08:14 AM   #12
Wolverine 1945's Avatar
Our old Flagstaff TT had slidouts trays on both sides,,, it was a 2006 829RBSS,,, not sure if it would be possible to buy replacement trays !!! They were very well made !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-29-2016, 08:22 AM   #13
Newly Retired
Steveboe's Avatar
This are all great ideas for helping out with storage.
So far on my unit I have things in boxes and plastic crates and use a broom handle with a hook on the end to fish them out as needed.
A simple and quick thing to use to grab whats needed.
Happy Camping
Steveboe is offline   Reply With Quote
Old 12-29-2016, 08:36 AM   #14
Different Storks for Different Folks !!!
LOL !!!
Old 12-30-2016, 12:42 PM   #15
cburchel's Avatar
I like this idea best. The pull out drawers are cool but I don't need anything that sophisticated. I will attach it to the aluminum framing. May use the stuff lowes sales. It's like a black plastic strip that you can add hooks, shelves, baskets, and so on.
Old 12-30-2016, 12:47 PM   #16
cburchel's Avatar
after looking at the pic more, it is a shame they didn't put a little bit bigger storage door in it.
Old 12-30-2016, 12:56 PM   #17
Yep... the sliding drawers are nice, don't get me wrong but they really don't ADD storage space, they just make it more convenient to get to the stuff in the middle. And as mentioned, if the cargo door happens to not be as big as the cargo space, then you are limited to what size drawer can slide in and out of the door.
I was looking for another level of shelving so I didn't have to stack stuff on top of stuff. The shelves did the trick for me. I have enough track that I could add another shelf (above or below) if I wanted.
Old 12-30-2016, 01:00 PM   #18
cburchel's Avatar
Here is the stuff from lowes I was talking about. I used it in my garage a month or so ago. Never even thought about the camper.
ID:	127336   Click image for larger version
Old 12-30-2016, 01:04 PM   #19
cburchel's Avatar
and you can also get the shelves like yours but i don't think you can flip them. so the baskets may be a better option.
Old 12-30-2016, 01:11 PM   #20
That should work!
Enjoy!
storage
