So I'm putting our Forester into storage this week. It will be in a Pole barn. I've filled the gas tank added fuel stabilizer but I forgot to fill up the propane tank when I filled up. Should I fill the propane tank or does it matter? Thanks
propane tank is sealed
I use propane on a home gas stove in the kitchen all year with no problem... sometimes it runs out... worst thing that happens is when it is below zero for extended time sometimes condensation in the incoming gas line freezes and restricts the propane gas from coming inside the house... a heat tape insulated with foam fixed that.
