Old 05-24-2016, 06:58 PM   #1
storaging the motorhome fuel or very little
Hi all,
I'm wondering of your opinion, do you recommend filling up your motorhome when you put it in storage, or with the least amount of gas fuel as possible?
fastwilly is offline   Reply With Quote
Old 05-24-2016, 09:10 PM   #2
If you are talking long-term storage, I would fill it up and add some sta-bil to the tank. If the tank is low, it will accumulate moisture.
2015 Cherokee 274DBH
2015 Ram 3500
klrobert is offline   Reply With Quote
Old 05-24-2016, 09:11 PM   #3
ba964's Avatar
Fill it up and add a can of Sea Foam .
ba964 is offline   Reply With Quote
Old 05-25-2016, 06:13 AM   #4
Thanks for the quick reply,, I should have said for short term like three to five weeks.
Old 05-25-2016, 07:15 AM   #5
TURBS's Avatar
Definitely fill it and add seafoam!
Do not fill it with ethanol!
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-25-2016, 11:45 AM   #6
rsdata's Avatar
fill it up to eliminate possibility of moisture condensation but 3 to 5 weeks is not that long for a problem to develop... 3 to 5 months or longer I would add something like Sta-Bil
depending on your location you may NOT be able to purchase ethanol free fuel... certainly not in KY or OH...
2014 Shamrock 183
Old 05-25-2016, 11:48 AM   #7
I would always recommend that you store your RV with a full tank of fuel, whether it be diesel or gas. By doing this, you keep your "air gap" in your fuel tank at a minimum, thereby reducing the condensation of water in your tank.
Water in your tank is especially bad for diesels since it makes your desiccant filter fill up faster, plus subject your tank to corrosion. For gassers, the water can lead to tank corrosion plus hard starting and running.
Using SeaFoam or any other type of stabilizer, will help the fuel stay "fresher".
WayneLee is offline   Reply With Quote
Old 05-25-2016, 01:34 PM   #8
storing a motorhome with gas full or close to empty
Thank you all for your quick and helpful response.
I will be filling it from now on before putting in storage. We live and store it in Minnesota.
Old 05-27-2016, 08:31 AM   #9
Wolverine 1945's Avatar
I do store mine full with Sta-bil or Seafoam,,,
But I don't think gas tanks are any longer Metal !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-27-2016, 08:48 AM   #10
Thanks Wolverine!
Old 05-27-2016, 08:54 AM   #11
Broken Toe
Cowracer's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
Remember kids! Ethanol is for drinking, not for driving!
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 05-27-2016, 09:33 AM   #12
TURBS's Avatar
Tim
[emoji106][emoji106][emoji106][emoji23][emoji23][emoji23]
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-27-2016, 09:29 PM   #13
Check out a product called VALV TECH, available for Diesel or for Gasoline. Available in the pumped fuel at select Marinas but also available as an additive. Check out on their website, and I and friends could go on and on attesting to the fact that it does all of what it claims, which is extensive. I use in all fuel tanks that I will not be using for awhile. Good for 1 year storage if I remember correctly. No other product that I am aware of comes anywhere near it.
tuxedo is offline   Reply With Quote
motorhome
