Old 07-26-2018, 06:28 PM   #21
Damprid and lots of it. In the summer the sun cooks out the moisture in our 5ver. In the winter we store in a limestone mine and it is quite damp in there. A bunch of damprid always does the trick.
The Lieutenant is offline   Reply With Quote
Old 07-27-2018, 07:22 AM   #22
Wolverine 1945's Avatar
Originally Posted by ImTravis View Post
It is, it has to be the crystals..
I will check them out !!!
Thanks !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-28-2018, 05:53 AM   #23
I'm in coastal AL, RV under cover and closed up. I had some mold on my cabinets and started using a medium size dehumidifier and solved the problem. I have to empty the tanks 2X weekly but it has an auto shut off if the tank gets full. Happy with my solution.
2015 Solera 24R
2014 Mercedes Chassis
Karter is offline   Reply With Quote
Old 07-28-2018, 09:11 AM   #24
Could you attach a drain hose,,, and maybe drain it in the Shower Drain ???
Old 07-28-2018, 10:10 AM   #25
Yes, I could raise the unit and run a drain hose to the shower. RV is plugged in right next to my house so I just empty the bucket, how often depends on your humidity and water storage capacity.
mold
