Damprid and lots of it. In the summer the sun cooks out the moisture in our 5ver. In the winter we store in a limestone mine and it is quite damp in there. A bunch of damprid always does the trick.
I'm in coastal AL, RV under cover and closed up. I had some mold on my cabinets and started using a medium size dehumidifier and solved the problem. I have to empty the tanks 2X weekly but it has an auto shut off if the tank gets full. Happy with my solution.
Could you attach a drain hose,,, and maybe drain it in the Shower Drain ???
Yes, I could raise the unit and run a drain hose to the shower. RV is plugged in right next to my house so I just empty the bucket, how often depends on your humidity and water storage capacity.
