Old 03-29-2015, 07:03 PM   #1
2015 2503S Mini Lite
Saberwolf 700's Avatar
Suburban Hot Water Heater Q
Have a new 2015 Mini Lite with the Suburban hot water tank. Bought it at the end of last season and during our walk-through with the tec, he pointed out the electrical off/on switch at back of unit.
The switch was in what would be normally considered the on position, toggled up. He stated this was off. I questioned that and he assured me it was off. Well I guess I'm still questioning it and before I open it up I would like to confirm with other owners if this is correct. Not really wanting to burn it up before i get to use it.
2015 Rockwood Mini Lite 2503s
2014 Ram 1500 Big Horn 5.7 Hemi
Saberwolf 700 is offline   Reply With Quote
Old 03-29-2015, 07:05 PM   #2
TURBS's Avatar
Unless the switch is wired backwards on should be on and off should be off.
"On" is rocker flipoed down
"off" is rocker flipped up.
I also have an interior on/off switch so my outside switch stays "on" @ all times and we control it from inside the camper.
Turbs
Old 03-29-2015, 07:10 PM   #3
Not sure what you mean there. Simple way to ask is pushing the top in would seem to be 'on'. Pushing the bottom in would seem to be 'off'. Correct?
Old 03-29-2015, 07:13 PM   #4
fonzie's Avatar
Turbs
X2
Fonzie
Old 03-29-2015, 07:15 PM   #5
TURBS's Avatar
Fonzie's pic shows it all.
Up off
Down on
Turbs
Old 03-29-2015, 07:15 PM   #6
Tec was right, that just seems opposite to what my brain wants it to be. Thanks guys.
Old 03-29-2015, 07:15 PM   #7
Learjet's Avatar
it has a label on it like the pic above ^^^^
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is online now   Reply With Quote
Old 03-29-2015, 07:34 PM   #8
Mine does 'not' have any markings whatsoever. Just black. Maybe they ran out of white ink that day.
Old 03-29-2015, 07:45 PM   #9
Average Joe
MrJoe's Avatar
When in doubt, turn the breaker off. (-:
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-30-2015, 03:44 PM   #10
When in doubt
Alternatively, when in doubt, insure that the water heater is full of water before plugging shore power. If it heats up, its on.
DRiveWell is offline   Reply With Quote
heater, hot water, suburban, water, water heater
