Old 07-17-2018, 08:11 PM   #1
sammonilla's Avatar
sulphur smell from hot water
I have a suburban water heater and this season it has started to smell like sulfer. any idea's on how to clean out the tank?? I have already removed the anode rod and flushed it out with clean water but not sure if that will be enough
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 07-17-2018, 08:14 PM   #2
BuzzWolfAR's Avatar
Did you replace the anode?
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 07-17-2018, 08:16 PM   #3
Toy-aholic
It's normal, mine does it every unused week....first few minutes of a shower & it's gone....until it sits another week.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 07-17-2018, 08:45 PM   #4
wmtire's Avatar
You can check out Suburbans tutorials on this at video 5 of this link:
http://www.forestriverforums.com/for...ml#post1527599
and here is the direct video:
2011 Flagstaff 831 RLBSS
Old 07-17-2018, 10:55 PM   #5
sammonilla's Avatar
yes the anode has been replaced just truing to get the smell out of the PEX hose.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
Old 07-18-2018, 12:15 PM   #6
It's normal. If it's going to be more than a couple weeks between trips, I drain the wh. Suggest you run a bit of bleach water through the hot water system. It will kill the smell and sanitize the lines.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 07-18-2018, 12:18 PM   #7
Denver To Yuma In 90 Days
Might as well do the whole system while he's at it!
Fresh water tank and pump as well.
JohnD10 is offline   Reply With Quote
Old 07-18-2018, 08:39 PM   #8
BuzzWolfAR's Avatar
Agree, sanitize the system with bleach. Lots of utube videos will show you how.
Very easy process. I do it once a year.
Buzz & Jo Wolf
Old 07-18-2018, 10:14 PM   #9
Did you run RV antifreeze into your water heater? If so this will cause the hot water to smell. Best advice, don't run RV antifreeze through your hot water heater, bypass it.
tomrob1161 is offline   Reply With Quote
Old 07-18-2018, 10:45 PM   #10
Check the temperature setting. If the temperature is too low it will cause that. Set it to 140 if you can.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 07-19-2018, 12:49 AM   #11
bob213's Avatar
Could be your water source reacting to the magnesium anode rod. May need to change to an aluminum/zinc anode rod. (Not just plain aluminum)
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
hot water, water
