Old 07-02-2015, 06:41 AM   #11
Ive tried to push them and they seem solid, as in they won't move at all. Is there a way to test them or verify power to them ?
Cbigger87 is offline   Reply With Quote
Old 07-02-2015, 06:42 AM   #12
TURBS's Avatar
In the "files" section here on frf there is a suburban trouble shooting guide.
If your using the browser.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-02-2015, 06:44 AM   #13
TURBS's Avatar
On my suburban I can "hear" the "sizzle" when heating using electric.
TURBS
2011 32bhok Sabre
Old 07-02-2015, 06:47 AM   #14
As a test only, remove the rubber plugs and install a jumper across the terminals or just tape the terminals together AFTER YOU DISCONNECT THE SHORELINE. THIS WILL DETERMINE IF THE LIMIT IS BURNT OUT.
Old 07-02-2015, 09:07 AM   #15
If I put a jumper in there what should it do? Make hot water or a noise or what exactly do I check for.
Old 07-02-2015, 09:12 AM   #16
IF the limit is burned out, it will start heating the water when you plug in the shoreline. It is just a check and should not be used as a fix.
Old 07-02-2015, 10:17 AM   #17
OK. Soon as I'm off work I'll put a jumper in then plug it in and see what happens. I'll report back as soon as I do it
Old 07-02-2015, 04:06 PM   #18
Pulled it apart. Didn't put a jumper in because the small copper wire that runs from pin to pin in the red wire side was broken is this a hardware store part or camper store thing ?
Old 07-02-2015, 04:53 PM   #19
Camper store item. While you're in there, you might want to check the other one. I'd replace both with 140 ones to get the water hotter and therefore use less.
Old 07-02-2015, 08:06 PM   #20
Yea. I spoke to soon, once I looked at the other it was broken to. Camper store had them. Electric now works. Still no good on the gas side. I'm taking it out this weekend so once I get back ill dig further into that
salem
