Old 10-05-2016, 06:08 AM   #1
switch by my hyrdaulic pump
So I picked up a 2006 Wildcat 5th Wheel. I pretty much have most if not all but one thing figured out on operations of the beast... The hydraulic pump in the front that operates the front jacks and slide out. There is a white Rocker switch mounted right on the same plate as the motor.... not sure what its purpose is. Also there is a canister to the right with an adjustment screw underneath that is hooked to the hydraulic system.. what is that for?
Thank you so much.. if you need photos I can get some in a day or so
Thanks,
Adam
Blackbelt is offline   Reply With Quote
Old 10-05-2016, 06:11 AM   #2
AquaMan's Avatar
Photos would help.
2016 Georgetown 364TS
Nights Camped 2017 - 16
Old 10-05-2016, 06:33 AM   #3
Oakman's Avatar
Thanks,
Adam
On my 2004 and 2008 Wildcat that white switch operated the slideouts. In all the years I owned those Wildcats I never used that switch.
I can't help with the canister but since I didn't have hydraulic landing gear perhaps it has to do with that. Pictures would help.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
pump, switch
