Old 07-02-2015, 10:03 AM   #11
MS Coast!!!!
gtony2
gtony2 is offline   Reply With Quote
Old 07-02-2015, 10:08 AM   #12
Iwannacamp's Avatar
I am real close to the south.... it gets down to 10-15 here... only 300 miles more south to far as you can go here...
Old 07-02-2015, 10:10 AM   #13
Iwannacamp's Avatar
BTW... it got to freezing in Houston this year... couple years ago they had snow on the ground in Houston
Old 07-02-2015, 10:51 AM   #14
Toadman
We live in Wisconsin where the winters are plenty long and cold. We have used the blow-out method for several years on 2 different TT without any problems. We just systematically go from one end of the camper to the other making sure that all water is out of the water heater first, do cold water valves and toilets, showers, sinks and then move to hot water valves. Also we have low point drains that I leave open and finally, we add RV to all traps, drains and to the toilets. Never have had an issue.
Toadman is offline   Reply With Quote
Old 07-02-2015, 12:00 PM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
Originally Posted by Wolverine 1945 View Post
I am with ChooChoo Man !!!
Sure the H do not want any lines to freeze !!!
Just don't forget the filter canister like I did !!!
I still have not been able to find by-pass plug for the filter Sys.
that some one said was made ???
Anyone know of one ???
Use a water heater bypass kit for the filter. The type with 2 valves from camco. I got this tip from my dealer, Rousseau's RV.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 07-02-2015, 12:09 PM   #16
Before you put any antifreeze in place the jug in the freezer overnight. If it freezes and expands you may have a bad batch of antifreeze. I've seen posts of defective stuff hitting the market.
edcronin01 is offline   Reply With Quote
Old 07-03-2015, 06:37 AM   #17
Wolverine 1945's Avatar
That would probably work Choo Choo,,, if you had room to install it,,, I was think there was a by-pass plug made,,, like the plug you can get to by-pass a Refrigerator filter !
Maybe it is just something I have dreamed up !!!
I will in the future make Damm sure the canister in empty after blowing Sys. out !!!
Wolverine 1945 is offline   Reply With Quote
water
