Old 10-11-2016, 06:32 PM   #1
Tank heat pads
Going to North Texas in mid November. At what temperature would need to switch on tank heat.
rickkey2 is offline   Reply With Quote
Old 10-11-2016, 07:17 PM   #2
32 or below.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 10-11-2016, 07:37 PM   #3
Tank Heat
Thank you for the reply, I just found in my paperwork that the tank heaters are thermostat controlled to come on at 45 and turn off at 67. This makes sense as you would want to start the heating process before the freezing point to heat the liquid in the tank. So I will turn the switch on if it is to be below 32.
tank
