Old 05-07-2011, 06:21 AM   #11
cheese53073's Avatar
Our friends have a keystone, to use the manual slide crank they would need to punch a hole in the skirting next to their steps. We haven't received our rockwood yet so I cannot tell you if the same holds true for us.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 05-07-2011, 06:51 AM   #12
Herk7769's Avatar
Man, that just does not sound right. That hole (if needed) should already be there. This is what it should look like.
This manual extension stub works the Opposite Side Slide. Look for the hole in the skirt opposite the slide you want to crank in or out.
Name:	9 Nov 2009 003.jpg
ID:	5646   Click image for larger version
Name:	9 Nov 2009 006.jpg
ID:	5647   Click image for larger version
Name:	9 Nov 2009 002.jpg
HAM CALLSIGN - KC3FFW
Old 05-07-2011, 09:49 AM   #13
Glenn5995's Avatar
Originally Posted by herk7769 View Post
They are DC so will run off the battery (or the converter when on shore power). They draw 65 watts (about 5.4 amps) each when "on" (They do cycle). 16 and a half amps is quite a draw if you are on battery only.
Very true, but only part of the story. If you are using the tank heaters, there is a pretty good chance you are also using the furnace quite a bit, especially in a poorly insulated ultralite. In my case I have 4 tanks (2grey, 1 black and 1 fresh), so 21.6 amps plus the furnace = getting up in the middle of the night and starting the generator!
How do I know this? Well....................
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
ultralite
