Old 05-04-2011, 05:10 PM   #1
Tank Warmers in Rockwood Ultralites
Just snagged our spankin new 2304s, and we are feeling pretty good about moving up from a Funfinder 189FBS. Cannot believe the difference in space and livibility. QUESTION: Just what tanks are heated? Dealer was not sure, but thought it was the water tank. There is a switch that deploys heat somewhere. Would be nice to know which tanks or all. QUESTION: They supply a crank for manually retracting the slide. Nobody in dealership knew where one puts the crank. Does anybody know? Currently rolling home to Canada from Florence Or., where we made our purchase. Loooookin good.
flugelboneman is offline   Reply With Quote
Old 05-04-2011, 05:18 PM   #2
sherdep's Avatar
the Heated tank option is the black electric pads that keep your tanks from freezing.
They place one pad on the bottom of the grey and black tank and also around the grey water pipe and black tank pipe.
I do not remember if it was on the fesh water or not though without going outside and taking a look
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-04-2011, 06:06 PM   #3
yvesm's Avatar
We have a 2902SS and all 3 tanks and drain lines are heated. I would have to add extra heaters on the drain lines (on the valves) and also on the fresh water supply line that comes out of the water tank to use it in freezing weather.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 05-04-2011, 06:17 PM   #4
We have a 2313ss and all of the tanks are heated black gray galley and fresh water tanks are heated
Matthews1 is offline   Reply With Quote
Old 05-04-2011, 07:13 PM   #5
We have the tank heaters on our Rockwood 2605S and they are on the black and grey holding tanks (we two grey and one black). Our fresh water tank is inside under the bed, so no heater on it. Here is the website: UltraHeat, Inc. - Easy to Operate. Before you turn the heaters on, make sure there is water in each of the tanks, per the operating instructions. And I believe the heaters use a lot of electricity, so would run the battery(ies) down rather quickly if not plugged into shower power. We've never used ours, but it is nice to know we have them in case we ever need them.
Momma Tac is offline   Reply With Quote
Old 05-05-2011, 10:46 AM   #6
Additionally, they are thermostatically operated, so turning on the switch will not necesarily turn on the heaters, only enable them to come on when the outside temperature gets cold enough.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 05-05-2011, 06:43 PM   #7
heated tanks
wow, thank you all for informative responses. nice bonus, although we live on vancouver island and not necessary most of the time. however, we camp year round, so one never knows. nice to know they are controlled by thermostat. i would guess they would not activate unless you were on shorepower, wot? these things would kill a battery PDQ.
ian parsons
Old 05-05-2011, 07:53 PM   #8
Wanna Be Camper
SaskCampers's Avatar
Hi,
Seems you are in good hands for the heaters so I will address the slide. On the side opposite the slide, you should see a small hole in the side of the trailer down lown on the side. It should have a black gromet around it or it may even be in the stair well. That is where you insert the manual crank handle to open and close the slide.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-06-2011, 10:09 PM   #9
manual slide crank
thx sasks, from a native of kamsack, many years ago. i will check both locations, and hope i never have to use the crank. always good to know where to go tho.
Old 05-06-2011, 10:17 PM   #10
Herk7769's Avatar
ian parsons
They are DC so will run off the battery (or the converter when on shore power). They draw 65 watts (about 5.4 amps) each when "on" (They do cycle). 16 and a half amps is quite a draw if you are on battery only.
http://www.annodindustries.com/shop/
The new web site...
Name:	Horst Probe Install 006.jpg
ID:	5644   Click image for larger version
Name:	Horst Probe Install 012.jpg
HAM CALLSIGN - KC3FFW
ultralite
