Old 12-14-2019, 10:07 PM   #1
Tanks are supposedly “full”
I know my tanks are empty but the monitor is saying otherwise.
Any thoughts, suggestions, and recommendations would be greatly appreciated.
Randy in Texas
TV - 2013 Ford F-250 PS Diesel
TT - 2014 Palomino Puma 28DSBS
Grif76040 is offline   Reply With Quote
Old 12-14-2019, 11:02 PM   #2
Disregard the gauges. They are rarely accurate.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
CedarCreekWoody is offline   Reply With Quote
Old 12-14-2019, 11:43 PM   #3
Fill tanks 2/3 full. Add 1 cup Dawn Dish Liquid and 1 cup Calgon water softener. Some use Borax. Drive a hundred miles. Maybe let it sit for a day or two. Dump and rinse. That often cleans my sensors and they work perfectly for about six weeks. Then I repeat.
AbdRahim is online now   Reply With Quote
Old 12-14-2019, 11:46 PM   #4
dbledan's Avatar
The ones that come with the RV are usually just screws sticking out in the tank. A little TP and they show full even when not. Grey water is not much better. The only one that sort of works is the fresh water.
If you want something more accurate this would do it but requires getting into underbelly and proper placement outside the tank and then stealing a wire to send to the updates panel. Since it requires dropping chloroplast and maybe even the tank I have not done it yet...
https://www.rvupgradestore.com/RV-Ta...stem-s/164.htm
dbledan is online now   Reply With Quote
Old 12-14-2019, 11:59 PM   #5
Oaklevel's Avatar
X 2
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 12-15-2019, 10:18 AM   #6
The only way I have found to make the factory gauges accurate more times than not it to make sure the tanks are clean when emptied.
To help this process I use a tank chemical that for me has proven very effective over the years. Odorlos brand not only keeps the odor down but also has pretty much dissolved the "solids" in the black tank.
Unless I'm in an RV park for an extended period of time (rarely) I dump my tanks after driving down the highway, usually dumping at a Highway Rest stop or when I get home and dump at the local waste treatment plant. Before I start out on my dump run or homeward bound trip I add as much water as I can to the black tank so things are well diluted and mixed.
Also essential is a good "rinse". If there is a built in flush system, use it. I bought an extra adapter with quick disconnect that is used to blow out water system when winterizing. Screwing it into the black tank flush inlet allows me to just press the hose at Rest Area dump stations on the "nipple" and then push the button for flushing. Works great but it takes several pushes of the timer button to really flush.
If no flush system hopefully the bathroom has a window that you can snake the flush hose in and flush through the toilet valve.
For the Gray Tank I use some citrus smelling tablets, placing one in the kitchen sink drain and flushing in with a quart of water. It cuts down any odor from the gray tank and also dissolves the soap and grease that fouls the gray tank sensors.
Transitioning from flush toilets and sink drains that go directly to a sewer system, to a holding tank system with finite storage capability, can be enlightening to many but in time everyone learns the ropes.
Lots of water, a little chemical designed for the purpose, and a good cleaning after dumping (flush), will keep things working as well as possible.
When frustrated just think back to what it was like when camping in a tent.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-15-2019, 01:32 PM   #7
Changing to the SeeLevel system is absolutely, positively the best upgrade I've done to my RV. No more false readings, no more guesswork. They accurately report in 1% increments.
They come with 3M double stick tape and go on the OUTSIDe of the tanks. They only need one pair of EXISTING sensor wires for the whole system. I installed it myself and couldn't be happier!
2015 Forester MBS 2401 WS
bob5560g is offline   Reply With Quote
Old 12-15-2019, 01:47 PM   #8
x2 on what AbdRahim said.
You might also add a cup of Ridex liquid to the other products.
After each emptying, I add a cup of Palmolive liquid dish detergent, a cap full of Calgon water softener, and occasionally a cup of Ridex, when the first two additives need a little help.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 12-15-2019, 02:26 PM   #9
Thank you for all the advice. I’m going to try the chemical route. I would hate trying to gain access to the tanks.
Randy in Texas
Old 12-15-2019, 02:33 PM   #10
For the price it better be good.
For only $32 (set of four) one could put these sensors in the black that have a "roof" over the sensor wire that keeps toilet paper from shorting them out. Fits the same holes as factory "probes" if in 3/8" holes. If only screws through the side, drill a 3/8" hole (pilot hole is already there when screw is removed).
BTW, one method that takes no "sensors" is to just turn the water off, lift the lid of the toilet, press dump valve to open, then just look down the hole. You can "See Level" for yourself.
2004 Nissan Titan
Old 12-15-2019, 02:33 PM   #11
we never use the gauges either. If they work fine, if not oh well!
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 12-15-2019, 03:10 PM   #12
MT Biker's Avatar
Our Black tank shows full when empty and empty when full, our grey tank will register what ever it feels like on any given day.
https://www.facebook.com/westshorerailway/
2019 Ford F-250 Super Cab 6.2L Lariat
2016 ML23FB
MT Biker is offline   Reply With Quote
Old 12-15-2019, 06:12 PM   #13
PokieandBill's Avatar
Anybody install a seelevel on a 2109DS?
Right out of the gate our level gauges are carrying on the long tradition of being crap. I like the look of the SeeLevel, but wondering how hard it is to access the tanks? Any tips? TIA
PokieandBill is offline   Reply With Quote
Old 12-15-2019, 06:17 PM   #14
bikendan's Avatar
Since you don't have your RV listed in your profile nor in your post, kinda of hard to advise.
Does it have a covered underbelly or not?
Equalizer WDH
Old 12-15-2019, 06:27 PM   #15
Hi BikenDan, Sorry it's my first post on this forum. I just filled in model info in my profile. In my defense, I did list the model in subject line. Flagstaff 2109DS MicroLite. The bottom is covered.
Old 12-15-2019, 07:52 PM   #16
And now that I've realized I have to save changes, more info in my profile. How do I get a signature in there?
Click on User CP (upper left on this page), then click on Edit Signature.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 12-15-2019, 08:36 PM   #17
Thanks, Boondock! I eventually made it to FAQs, maybe my sig will work now.
Bill, Teri and Gauge (the most handsome pooch).
2019 MicroLite 2109DS
2008 Airstream Safari SE
2012 Tundra
Palisade, CO & Cornville, AZ. That's right, two places nobody has ever heard of.
Old 12-15-2019, 08:51 PM   #18
bikendan's Avatar
The subject line/Title of this thread Is "Tanks are supposedly full" and your model is not listed in the title.
So I'm confused as to what subject line you're referring to.
Equalizer WDH
Old 12-15-2019, 10:09 PM   #19
NMWildcat's Avatar
He is new and trying, give him a break!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-15-2019, 10:14 PM   #20
bikendan's Avatar
I'm trying to understand so I can help by moving their posts to its own thread or a better sub-forum.
Equalizer WDH
tank
