Old 08-18-2016, 12:46 PM   #1
The Android Tablet???
I just bought a 2015 Vibe BHS308 in June. It came with the Android Tablet that has an app on it to allow you to lower the power stabilizers, extend/retract the slides, extent/retract the awning, and even turn on the awning lights. This is all cool.....however, the app that does all this, goes away every time I unplug the docking cable. Its just no longer there. Comes back as soon as I plug the cable back in. If I have to stand inside the camper to use it (its mounted directly above the regular controls for most of these items), what good is it.
When we did our walk thru at the dealer, they told me that it stopped working because their own wifi signal was too strong and over powered the hub in the camper. While I'm not an RF engineer, I am a network engineer and after getting home and thinking about, this does not make a lot of sense to me. If its merely a wifi signal from the hub and the app is hosted on the hub rather than the tablet, it should still be able to connect. Anyone that runs a wifi network in their home will know that most of their neighbors have wifi too and everything generally works fine.
Has anyone else encountered this and if so, how do I fix it?
TT - 2015 Forest River Vibe 308BHS
TV - 2005 Nissan Titan 4X4
bfindley is offline   Reply With Quote
Old 08-18-2016, 12:57 PM   #2
Go into your wifi settings and forget all networks except the one that connects to your camper. That should keep it from connecting elsewhere.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 08-18-2016, 01:09 PM   #3
Thanks, I'll give that a shot. Perhaps the dealer set up a network on it....
Old 08-18-2016, 02:24 PM   #4
Head Rambler
They may have never connected the tablet to the MyRV wireless network, or may have removed it from the tablet at some point. There's a section in the manual on how to do that. You'll need to get the hub's SSID and Password off the hub itself.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-18-2016, 02:57 PM   #5
Thanks, I'll look at that while I'm in there too. That sounds very likely. I do know that when I picked up the camper they were in the middle of putting in a new tablet. I appreciate all the tips.
Old 08-20-2016, 10:29 AM   #6
Bdcclc05's Avatar
We also own a 308 we had same problem 6 mths back (once we convinced forest River that we had a wireless router ) we got a new wireless router fixed problem. Same tablet new router.Click image for larger version
Name:	ImageUploadedByForest River Forums1471703301.114091.jpg
ID:	117878 it is located behind the trash can by the hot water tank.
Bdcclc05 is offline   Reply With Quote
Old 08-20-2016, 10:50 AM   #7
Flybob's Avatar
Wireless router being too strong sounds like an excuse for I don't know how to connect it. If it has not been registered with the router it will only work when physically connected. Use the connect to network procedure for the tablet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-20-2016, 04:20 PM   #8
Bdcclc05's Avatar
Flybob may have a point they did say when we bought ours that FR gave them no training on the link pad system. Ours worked when we got our camper then just quit doing the same thing that you described and we had no power from the little box on front of router but had power to that box. It is all one unit so they sent us a new wireless router and password (under warranty).
Old 08-20-2016, 04:22 PM   #9
Bdcclc05's Avatar
Forgot the other way to check is with ur smart phone search for wireless network it should pull up your my rv network if router is working.
Old 08-21-2016, 09:29 AM   #10
Head Rambler
I can't remember if they hide the SSID on those routers, but if they don't, then a smart phone or tablet will certainly find it.
Gotta go campin!
