Old 10-15-2008, 10:18 PM   #1
highwayman's Avatar
The guy who came up with my Water Filter Placement, wasn't thinking
I had the recent pleasure of dealing with it winterizing my 2009 Sandpiper 332 RLD. The tech during the walk thru warned me you might want to fashion a small catch bowel to catch most of the spillage, as you will have difficulty bringing a full container thru the bathroom vanity counter opening. No kiddin!
Came up with a turkey baster to draw most of the fluid off to get it out of there without drowning. I really got to envey those that have their filters in clear areas like the storage compartments. My old rv had a an outside add on filter system at the water hookup.
highwayman is offline   Reply With Quote
Old 10-16-2008, 04:12 AM   #2
My filter canister is under the entertainment center, I put a small plastic bucket under the canister before I disconnect it.
Old 10-16-2008, 10:07 AM   #3
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Roger,
My Salem filter is in the same location. When I change mine, I put a bowl under the filter, unscrew the housing, then dump a little in the bowl. That way, the housing can be tilted to fit out the hole...where I can dump the rest out, and change the filter easily.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 10-17-2008, 10:16 AM   #4
Dodge Guy's Avatar
Mine is under the vanity. I just use a towel under the canister to catch any spills.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-17-2008, 04:11 PM   #5
Water Filter
I feel so bad for you folk! I can't even reach mine. I have a Flagstaff and the water filter is in the storage area under the bed, that only be reached from the outside, and is about 6" past arms length away. I will be finding an exterior filter this spring. Oh Yes! The water filter sets above the water pump. I had to remove a flimsy wood panel to even find the water filter.
Who designed this!
Life is something to do when you've finished breakfast
Chuck & Margie
Both Retired
08 2500HD Silverado 6.6L Duramax
Flagstaff 829fkss
Round Mound of Sound is offline   Reply With Quote
