Old 04-02-2008, 07:13 PM   #1
cmprguy's Avatar
The mystery key
Hi Everyone!! Heres a good one for ya`ll! I have so far purchased 2 brand new TT`s. Each time i was given the full set of keys. The ones for the Main entrance door and the baggage compartment doors. On both occasions I have recieved a `gold` colored key. It looks exactly like the baggage door key but has a slightly different cut. I asked the dealer on the second delivery what it went to and they had no clue whatsoever!
Any ideas?????
Joel
cmprguy is offline   Reply With Quote
Old 04-02-2008, 08:02 PM   #2
Grape Escape
Outside shower?
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-02-2008, 08:06 PM   #3
If you look at your keys you will see a set of number, those numbers should match the numbers on your locks. The numbers are located at the key way( this is where you put your key in the lock). If you can not match the gold key to any number on your camper, then I would contact the manufacture. You should have three keys, one set for the cargo or storage, one set for the dead bolt for the entery doors and a set for the door handles.
Old 04-02-2008, 08:09 PM   #4
Maybe you have a hidden safe.
choice spot is offline   Reply With Quote
Old 04-02-2008, 08:30 PM   #5
cmprguy's Avatar
LOL!!! A hidden safe!!! Nice
Well..the dead bolt would make sense..but the key doesnt work it. The key that works the door handle aslo works the deadbolt. So why lock the deadbolt! Der. My last TT was like that too. and the other key wroks the cargo/shower locks.
I must just be special to get two useless golden keys!!
Joel
Oh..I know!! Maybe it unlocks the secrets to the concertone radios!!!!!
Old 04-02-2008, 08:52 PM   #6
If you pull the door handle like you are going to open it and look up under it you will see the cam that is attached to the back of the cylinder, if the cam is forced out of position and the dead bolt is not used then the door will open. As far as the dead bolt even though you can use the same key to open both locks the cam to the dead bolt is consealed in side of the door. I suggest, if you are going to lock just one lock use the dead bolt.
Old 04-02-2008, 09:28 PM   #7
welshman599's Avatar
Send a message via MSN to welshman599
It's the key to your dealer's heart I guess. I have no idea.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 04-02-2008, 10:15 PM   #8
As far as it being the key to the secret of the concertone i think thats very unlikely since none are known to exsist. LOL Does your camper have a lock on your spare tire ?
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 04-03-2008, 10:58 AM   #9
KyDan's Avatar
You lock the deadbolt because it's possible for the door to vibrate
open on the road if you just lock the handle latch.
With the dead bolt locked it's much less likely to happen.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-03-2008, 11:11 AM   #10
Head Rambler
A lot of RV's come with a security box under the bed. It could be the key to that. I don't see it mentioned on the site but you never know.
Gotta go campin!
