Old 08-25-2015, 12:21 PM   #11
Platokidd's Avatar
Originally Posted by Flybob View Post
You may have a quick chill vent on your roof AC. Check for what looks like closed vent on the inside AC panel ( next to the return vent). There should be a small tab that you can slide sideways to open that vent. It allows cold air to pour out and not be channeled through the ducts. If you have a very hot humid day which is causing the coils to freeze up you can open this vent to have maximum air flow and prevent freeze up. Once inside cools some, you can close it and AC will work as normal.
Always use my quick chill vent Just didn't know thats what its call. I call it something else..dont ask
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 08-25-2015, 12:32 PM   #12
TURBS's Avatar
I think the actual dometic term is "quick cool dump"
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-25-2015, 01:39 PM   #13
I don't think most people turn off the propane when going in gas stations or tunnels
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-25-2015, 01:48 PM   #14
You are probably correct...but most people are not always right. I would turn it off if my frig propane burner was located anywhere near potential gasoline fumes. Tunnels are a different story.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-25-2015, 02:51 PM   #15
bob213's Avatar
OK call me ignorant but here is a picture of the outside vent on my Surveyor. Another of 1 of 2 tabs at the bottom. So I don't break anything, how does the vent open?
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 08-25-2015, 03:03 PM   #16
Do you know where your GFI is on your wall plugs? you would think it was on one of the two plugs that are nearest the kitchen sink. Nope, not in my 5th wheel! after 8 days of what i assumed was a blown fuse, where 4 plugs quit working, after pulling out all the fuses one by one and checking them against a new fuse, still no idea what was happening. i was ready to call a service person, to help figure it out..( i am seasonal) by accident, i discovered a GFI plug above the bathroom sink/ below the bathroom mirror. in the 12 years i have owned the trailer, i have never blown a fuse, or used that plug! i saw that the GFI button had popped, and pushed it back in, and Wa La, i have power back in the the 4 plugs! I sure wish there was a video that came with each camper to take you through all these seemingly simple things that you need to know about.
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 08-25-2015, 03:06 PM   #17
it opens by the air pushing it out, when the exhaust fan is on!
Originally Posted by bob213 View Post
Attachment 86848
Attachment 86849
Old 08-25-2015, 03:11 PM   #18
panthercity's Avatar
On our 30THSS, the flap is snapped closed and must be snapped open.
Certified JB Welder. Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
Getting old is just a matter of narrowly missing all the things that kill you.
panthercity is offline   Reply With Quote
Old 08-25-2015, 03:14 PM   #19
DaveSchwartz's Avatar
You push up on the two tabs near the bottom corners of the inner flap. You have to press upwards quite firmly - harder than you would expect. Same thing when closing - push up and in with your thumbs. I preferred the small turn tabs on the stationary frame in my old TT but I guess that was two parts that had to be inserted by hand as opposed to a single molded piece. Even China has to cost reduce to keep from losing jobs to third-world countries even farther down the chain!
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-25-2015, 03:44 PM   #20
rsdata's Avatar
DaveSchwartz...
you learn something new everyday here... I luv this place...
I will reiterate that pushing up is harder then it should be, also put pressure on your thumbs to pull out at the same time as pressing up to help release the plastic tab...
I always wondered why my range vent did NOT vent smoke from the burners???? Can't do it if the outside vent is snapped closed.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
camper, parts
