Old 07-29-2019, 09:38 PM   #1
The toilet!
Many sorry’s If this has been posted before. Newbie here.
We leave the dump station, after lots of flushing, and we get home and there is “Pee” all over the floor. Help?
Lyle22 is offline   Reply With Quote
Old 07-29-2019, 10:14 PM   #2
Welcome... I see it's your 1st post.
What brand/model toilet?
There were problems with the Dometic 300.
A forum search will bring up lots of posts.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-29-2019, 10:47 PM   #3
Blackrock's Avatar
Were you flushing with the black tank gate closed at any time?
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-30-2019, 08:42 AM   #4
Head Rambler
It may also help if we knew the make and model of the RV as well as the toilet.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-30-2019, 09:09 AM   #5
SlowrideHD's Avatar
Don't pee on the floor.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 07-30-2019, 01:08 PM   #6
Traveling along
Bill and Margo's Avatar
Sounds like you were traveling. Did you close the lid?? Anytime the trailer is moved, close the lid to prevent splashes.
Bill and Margo
Traveling Along
2019 Silverado 2500
2019 Primetime Crusader 29rsle
Bill and Margo is offline   Reply With Quote
Old 07-30-2019, 09:33 PM   #7
Nope. Just get back home and smell pee. Have pictures
Old 07-30-2019, 09:34 PM   #8
Forest river. Geopro. 19fd
Old 07-30-2019, 09:36 PM   #9
No.didnt do that
Old 07-30-2019, 09:37 PM   #10
Thanks!
Old 07-30-2019, 09:38 PM   #11
How many times have you dumped the holding tank since you owned the GeoPro?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 07-30-2019, 09:39 PM   #12
...nice
Old 07-30-2019, 09:40 PM   #13
At least 12 times
Old 07-30-2019, 09:45 PM   #14
Is the black water tank empty when you look down through the open the toilet "hole".
Shine a flashlight if needed.
Were you using a deodorizer that turns the contents blue or green?
Was the pee tinted blue or green?
Old 07-30-2019, 10:29 PM   #15
You smell p? You see p? Is it in front or back of toilet? Reason I ask is if you have a Dometic model 300 toilet there have been many posts about defects with this toilet. There should be a label on the side of the toilet. If a 300, call Dometic and they will replace.
If you have to replace you might want to upgrade toilets. Dometic can give you options.
2016 Siverback 33IK
Old 07-31-2019, 06:18 AM   #16
X2 on the dometic 300 problem. I chased pee smell for a while before I learned of the problem with them. The "inner void" of my toilet was nearly full. If you have one, use your phone to take a picture of the "void" from the hole in the upper back where the water hose goes in for the sprayer. Dometic was great about replacing it, and the replacement has worked well.
Griff02 is offline   Reply With Quote
Old 07-31-2019, 09:29 PM   #17
Just passed a year of ownership. Probably 15 dumps (?)
Old 07-31-2019, 09:30 PM   #18
Thanks!! How do I post pictures here? Sorry am a bit of a caveman. lol
Old 08-02-2019, 11:12 AM   #19
See that paperclip? When you click it, it'll open a window that has several spots that say "browse". Click browse, find your photo and double click it, then click "upload" and then close that window. At the bottom, under "additional options" you should then see a file under "attach files" and right above "manage attachments". You don't need to click anything...just post.
Mrs.Shockley is offline   Reply With Quote
