03-10-2016, 02:29 PM
#21
I have the Andersens and love 'em. I also use extended X-Chocks to cut down to trailer shake. My X-Chocks came with a warning stating they are NOT to hold the trailer in place, only to reduce trailer shake.
03-10-2016, 02:37 PM
#22
When we had our TT we used the Andersens if needed and the Fastway ONE Steps on the other side. If we didn't need the Andersen we used 2 Fastway's.
We had an issue one time with the xchalks while on a bit of an incline.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
03-10-2016, 03:39 PM
#23
I now use OneStep after owning X-Chocks. You still have to added wedge type chocks when using the X-Chocks and you not suppose to put the X-Chocks in after you level and remove them before hook up. Seems like every time I went to remove the wedge chocks I had to more the forward or back to get them out. Now with OneStep I just grab and go. I never felt X-Chocks help all that much nor do I expect the OneStep to work much better.
Kinda Interesting that BAL that makes the X-Chock also makes one similar to the OneStep and BAL makes the same claim with them.
BAL - Innovative Products for the RV Industry
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
03-10-2016, 04:16 PM
#24
I know from experience that you should still chock the tires opposite the Anderson's. I didn't the first time using them and when I went to leave discovered that the un-chocked side had rolled. Not much ... maybe just an inch or so ... but enough to put strain on the scissor jacks on that side. Now I level with the Anderson's (LOVE 'em) and use regular, cheap yellow chocks on opposite side ..... one each in front of front tire and behind rear tire to control movement in either direction.
03-10-2016, 05:07 PM
#25
I use Anderson revelers on 27 ft Rockwood, pull up on the big rocker wedges, place the chicks provided under the tapered end of the rockets. This Does chock the raised wheels, unless you're all the way to the 3" end. I chock front and back of low side, and also use X Chicks between tires on both sides. Keeps the trailer in.place, and steady.
TN Cowboy
2006 Rockwood 2601
2007 GMC SIERRA 1500
Rv'n since 2002
03-10-2016, 06:11 PM
#26
When you back/pull onto the leveler, place a chock under each leveler as it will be raised off the ground. This causes a cradle for the tires to sit in. Then I put x-chocks on both sides of the trailer
03-10-2016, 11:39 PM
#27
Rivnut
Originally Posted by flymhi
X2! I have two x-chocks that I need to sell but will be buying new xtended x-chocks for our new spread axle unit. They sure do make things secure just like emergency brakes on a car. If you are interested in the regular x-chocks, let me know and I'll make a deal since you are local.
Always take a board alone so you don't butt then in soft ground like I did.
03-11-2016, 07:29 AM
#28
Originally Posted by Dinostop
Flymhi I might be willing to do an equal trade. I believe I have the extended ones but need the regular ones. I will know for sure this weekend when I pick my unit up from storage. I got a new camper in the fall and I think the spacing narrower than the last unit I had
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Shoot me a pm if that's the case.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
03-11-2016, 08:08 AM
#29
this is how we remove the Andersen Leveler chock piece when I'm ready to come off the AL. When I move forward just a bit to take the weight off the chock, my wife can easily and safely pull both out of the way without having to get down near the tire to remove them. Then I can roll back off the AL. The eye bolts can be put in from either side, depending on which side of the trailer the AL is on. Works great and she stands back away from any danger.
03-11-2016, 08:37 AM
#30
I have the andersen leveler and had to cut about 4" of each, I also put stair step non-slip on each. I have two X-Chock installed to stop the movement.
Retired Navy
2016 Flagstaff 26 FKWS
03-11-2016, 09:54 AM
#31
Gonna have to steal that idea.
Thanks,
Family of six, camping in a Grey Wolf 26DBH LTD pushing a 2010 Armada via 10k/1k HaulMaster WDH stopped by a Prodigy P2 brake controller
Tug: 2010 2wd Nissan Armada Titanium with tow package.
Specs: Max Trailer Weight 9,100, Tongue Load: 910, GCWR: 15,100, GVWR: 7,150, Payload: 1,592
03-11-2016, 10:16 AM
#32
We chock with the red chocks on the side with the Anderson Levelers, then X-Chock both sides to reduce movement in the trailer with walking around. We do not chock the opposite side and have never had a problem with the trailer moving at all.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
