Old 01-24-2016, 05:55 PM   #11
Blackhat6mike's Avatar
Many times when you have a blowout or tread separation, there is no rise in temp or pressure, just "BOOM".
The TPMS doesn't stop a faulty tire from exploding. It will only tell you when there is a potential problem or a catastrophic event. Many times, people have had blowouts and didn't know it till a passing car informed them. Otherwise, they could have driven till the remnants were set on fire or ground down to nothing but a metal rim. It happens often!
A TPMS doesn't "STOP" any problem, it only notifies you as to the temp, pressure, and any variances, in real time. It's up to you to use this information to whatever end.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-25-2016, 03:24 PM   #12
Originally Posted by boondocking View Post
It doesn't sound like your TPMS was doing you any justice if you have had four blowouts while using it. The TPMS should have given you enough warning that the pressure was building in the tire before it blow.
So, blowouts are from high pressure?
On a more serious note, TPMS- wouldn't leave home without it.
Brewhedd is offline   Reply With Quote
Old 01-25-2016, 03:28 PM   #13
I don't know?
You tell me what you think.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 01-25-2016, 03:31 PM   #14
ColoradoRick's Avatar
Yep...my advice for all new folks with RVs is to make their #1 upgrade a good set of TPMS sensors!!! (I'll never go without them, now, either.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 01-25-2016, 04:16 PM   #15
Mr. Dan's Avatar
My new TST 507 system is in the garage awaiting my next trip in March.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 01-25-2016, 06:13 PM   #16
I don't know?
I should have said blowouts can be caused from high pressure or low pressure. Low pressure causing the tire to heat up and become weak. A TPMS should indicate a state of low pressure and or temperature rise indicating something is wrong before it becomes a real problem.
I have the TST 507 and it tells me if there is an increase or decrease in PSI or an increase in temp.
2007 Surveyor SV230
Old 01-27-2016, 08:41 PM   #17
Kels4g's Avatar
Maybe some of you could link to the TPMS that you are using? That would be helpful for those of us considering.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
Kels4g is offline   Reply With Quote
Old 01-27-2016, 08:50 PM   #18
HONDAMAN174's Avatar
With what I know now, I would have gotten this:
Truck System Technologies TPMS 4 Sensor Tire Monitor System w Flow Thru Sensors https://www.amazon.com/dp/B00XNVA1B6..._egyQwb22APRH2
I currently am using the non flow thru sensors that I have to take off to add air.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-27-2016, 09:04 PM   #19
We use the TST 507RV with flow through sensors. Great company with personal service. The monitor is easy to setup and the company will provide you with extra "O" rings and seals for the sensors just by calling them. Great investment to make on any RV.
Old 01-27-2016, 09:37 PM   #20
Mr. Dan's Avatar
I bought the TST 507 system with flow-through sensors from these people. They had the best price I found at the time, they extended the normal 2-year warranty to 3 years and the product was shipped from the manufacturer!
Edit: Oh and Free Shipping!
http://www.infotechrvsolutions.com/TPMS.html
tire
