Old 01-23-2016, 06:45 PM   #1
spierce617's Avatar
Tire Monitors
I saw this while looking at new TT and trying to figure out what brand they are and how good they are. I know they are tire pressure monitors but not much more.
A little help will go a long way
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 01-23-2016, 06:52 PM   #2
Kenny kustom's Avatar
Tire Monitors
Never seen those before.
There might just be a little spring behind, and the air pressure pushes the green up.
Not that accurate.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-23-2016, 06:56 PM   #3
Flybob's Avatar
They are made by many companies . Just do a search on color indicating tire pressure caps. Which one you buy depends on the normal operating pressure as they are factory set. Although they are convenient they are not real accurate and only indicate lower than normal pressures not higher. It is a little more effort, but I recommend a good tire pressure gauge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-23-2016, 06:58 PM   #4
Todouble's Avatar
May be nothing more than a glorified cap? The green probably signifies nitrogen and the 50 might be the recommended pressure?? Just a guess
Todouble is offline   Reply With Quote
Old 01-23-2016, 07:04 PM   #5
The TST 507 are not cheap but they give me piece of mind, they work.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-23-2016, 07:06 PM   #6
Flybob's Avatar
They are actually 3 color monitoring caps, Example a 50 cap will be green for anything above 45 psi orange for 35-45psi and red below 35 psi. Set of 4 about $10. As I suggested a good tire pressure gauge.
TST Tire Monitors
2 100W solar panels
Old 01-23-2016, 07:13 PM   #7
spierce617's Avatar
I have a utility trailer that does more sitting than anything. From what you all are saying they are what I thought they were. Spring activated. I was thinking they would be OK to use on that but not the TT.
Old 01-23-2016, 07:26 PM   #8
Flybob's Avatar
Ok for utility trailer, Too much at stake to use on TT.
TST Tire Monitors
2 100W solar panels
Old 01-24-2016, 04:26 PM   #9
Blackhat6mike's Avatar
X2 FlyBob.
Those only tell you the approx pressure while you are standing there looking at them. You NEED a good TPMS that reports to you in real-time. You need to know when you have a problem [slow leak] before it becomes a much bigger problem [blowout].
I have used the TST 507 RV system for about two years and it has performed perfectly. I've had 4 blowouts and 2 slow leaks and each time the monitor let me know immediately. Wouldn't even think about leaving home without it.
You get what you pay for!! It will pay for itself over time. JMHO
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-24-2016, 05:12 PM   #10
It doesn't sound like your TPMS was doing you any justice if you have had four blowouts while using it. The TPMS should have given you enough warning that the pressure was building in the tire before it blow.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
tire
