Old 10-28-2015, 02:59 PM   #21
acadianbob's Avatar
Originally Posted by Gyrogearloose View Post
Thanks, youroo!
I've changed my tires to Kumho 857 trailer tires and raised the load rating to where it ought to be. In the process I made a new mistake. The Kumho's are size 205R14. I asked for 205/75R14 as recommended for my trailer. The new tires are 0.9" larger in diameter than I expected, which was not my intent. I'm now trying to figure out if this did any harm. The gap between the two tires was already small, and got smaller. This is my new concern.
I bought Kumho 857's awhile ago. Went from 205/75 to 195/82 to get the same circumference. I still have more capacity with the LR D 195's than I had with the LR C 205's. It's a great tire.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-28-2015, 03:02 PM   #22
Iwannacamp,
Yeah. I agree that it seems like a small increase.
I'm not worried about vertical dimensions; the clearances look fine.
It's the horizontal separation between tires that is a little bit alarming.
The separation between my two tires is now less than 2 inches.
0.9" makes a big difference in that separation.
I think I'm ok, but I'm a little queasy about it.
Gyrogearloose is offline   Reply With Quote
Old 10-28-2015, 03:06 PM   #23
Yeah. I think I saw you mention that in another thread.
It turns out that the dealer who sold me the 205R14s made the same mistake as I did in assuming they were 205/75R14s. He's willing to do an exchange for the 195s, but they're currently back ordered. This is giving me time to evaluate keeping the 205's. I'm torn about this because of the comfort I get from that 2270lb load capacity in the 205s.
Old 10-28-2015, 05:14 PM   #24
acadianbob's Avatar
It also depends on how you are doing your wheel chocks. Mine go between the 2 tires and there wouldn't have been room for the chocks if I had less clearance. So, that could be important.
Old 10-28-2015, 05:47 PM   #25
tstillman's Avatar
Originally Posted by Blackhat6mike View Post
The manufacturers put the cheapest tires on that can slip by the GVW of the trailer. IMHO, I suggest you go up a load rating over what it came with. I went down this road to the tune of 4 blowouts, three on one 350 mile trip.
Make sure your spare is upgraded also. I carry two spares.
Also, a TPMS is a must have.
2X this. Been there and blown that.
One thing to rember is that "ALL" ST trailer tires are made out side of the US. Having said that there are a few brands that stand out. Michelin, Maxxim, and Carlisle brands that although made in China or Taiwan have a good customer standing.
I also agree that a TPMS is curcial as it is usually a low tire pressure issue that leads to excessive heat build up that causes the blow out and will on any brand of tire you buy.
Good luck and happy trails.
Tom Stillman
Vancouver, WA
2012 Forest River Wildcat Sterling Edition
2010 Ford F350 Super cab (With all the junk taken off) With H&S tuner and set of bags on the back.
tstillman is offline   Reply With Quote
Old 10-28-2015, 06:27 PM   #26
I was more concerned about the very marginal o.e. tires .I was worried about front to rear loading problems so I opted for load range d tires. Still have marginal axles but you can't rebuild the whole trailer.
douglas dix is offline   Reply With Quote
Old 10-28-2015, 06:29 PM   #27
Yup, on all accounts.
One of my problems is the 205/75R14 size of my tires.
There aren't many D-rated tires in this size.
Old 10-28-2015, 10:43 PM   #28
accumack's Avatar
GyroGearloose, what was your actual loaded trailer weight on the scales?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-28-2015, 11:18 PM   #29
Gyro,so you went from a 15" OE size tires to 14" tires and Rims? Youroo!!
Old 10-29-2015, 01:05 AM   #30
Just a member
kandl's Avatar
Huh
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
tire
