Old 03-22-2012, 11:17 AM   #1
Retired
Tire Pressure Monitor
Does anyone use the tire pressure monitoring system I see advertised a lot in the trade magazines, such as N/Vision? We are new TT owners and I would like to know if they perform well, as I am considering purchasing a system. If the forum considers them as overall useful, then what is the best brand to choose? The other question being of course are they just a waste of money? Thanks for your advice in advance.
Mike
Sunwalker is offline   Reply With Quote
Old 03-22-2012, 11:40 AM   #2
acadianbob's Avatar
There are no doubt several brands that will do you well.
I just installed (yesterday) the Truck Systems Technologies 507 system. It was $259 for a 4 sensor system. It was easy to install, about 20 minutes total. It worked well right out of the box (as it should!). It has a diagram of your programmed wheels that shows you which wheel's data is being displayed. (one at a time). Then it shows you both pressure and temperature for that wheel. You can program your high and low pressure warning points as well as a temperature warning point.
Haven't used it on a towing trip yet but can easily see how it works. I've never had a tire issue but I always worried a little whether I know I had a problem in time to prevent an even bigger problem. So this provides some peace of mind in nothing else. Anything that makes the tow more comfortable and safer is good with me.
Anyone know of a bearing temp sensor? HA! Just kidding! But seriously, I wonder whether a bad bearing would raise the wheel temp enough to show up in the tire temperature warning? I hope I never find out!!
Here is the link for the system if you are interested.
tst systems
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-22-2012, 11:49 AM   #3
fonzie's Avatar
I have same system as acadianbob for a year now and it works great. On this system you can change the battery in the pressure sensors yourself, don't have to send to maufacturer. Well worth it.
Fonzie
Old 03-22-2012, 12:16 PM   #4
TURBS's Avatar
link to there website ?
Old 03-22-2012, 03:45 PM   #5
acadianbob's Avatar
In my first post.
Old 03-22-2012, 04:04 PM   #6
Mark and Linda's Avatar
My neighbor who has a fifth wheel has installed one of these systems on his rig. He likes the operation of it. He gave me the contact info so I can invest in one.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 03-22-2012, 04:16 PM   #7
MtnGuy's Avatar
Mike
No way are they overkill, or a waste of money. After an incident with my DD and SIL in which their tire shredded, but was witnessed as being flat before that happened, I am a firm believer that many of the so called "trailer tire blowouts" are actually flat tire conditions before the tire shreds due to low air.
I use a Advantage Pressure Pro system.
Old 03-22-2012, 05:38 PM   #8
acadianbob's Avatar
X2. And in a tandem system, if you don't know you have a flat, you can over-stress the remaining tire and ruin that one too. I've seen tandems on the side of the road with both tires flat on one side. Usually most of us only carry one spare. So, notice of an impending problem can save that other tire and a big headache.
Old 03-22-2012, 07:13 PM   #9
We also have a tst system after having two blowouts within a few miles. I had an issue with monitor not holding a charge and they replaced the unit under warranty.
Filthy Beast is offline   Reply With Quote
Old 03-22-2012, 08:57 PM   #10
Anacortesians
Wow! Technology has certainly got cheaper. When I was at Boeing (early 1990's) a TPMS for the 767 was over $2M. Okay, the environment is harsher than on an RV, it had to be FAA certified and there were 8 wheels on the main gear, but still!
Frank and Eileen
No longer RVers or FR owners
