Old 09-04-2015, 07:49 PM   #11
gashog's Avatar
Originally Posted by Ramblin Recks View Post
I just bought the TST 507RV from the manufacturer a few months ago. Got a 3 year warranty, and they have great customer service. I have the flow-thru sensors for my inner duals, but I need to change out the valve stem before I use those. Otherwise, I'm very satisfied with the display and the sensors. Was advised by TST to mount the repeater as far to the rear of the trailer as possible. I installed the repeater in my "communications" closet (the BR wall shared with the bathroom). I had no drop outs from the sensors. It was great keeping track of my tires on the Goshen trip.
I have to ask... you were "advised by TST to mount the repeater as far to the rear of the trailer as possible". Don't you mean the tow vehicle not trailer? It only makes sense that the repeater would be mounted somewhere between your TT tires (that have the transmitter sensors) and your Truck (where your receiver is). I mounted my repeater booster in the nose of my Windjammer to assist in getting the signal to my truck cab, I never lose the signal...
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 09-04-2015, 09:29 PM   #12
Blackhat6mike's Avatar
My relay is mounted on the power tongue jack and uses the wiring from the assist light. I put a waterproof cover over the toggle switch with a dab of Goop to hold it in place. Works fine.
My TST 507 is almost 2 years old and just now changing the batteries.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-05-2015, 08:17 AM   #13
CCRVOC
Ramblin Recks's Avatar
Nope.
TST customer support said "the further to the rear of the trailer the better". He said if I had a class A 40 ft pusher, it should be mounted in the engine compartment. In full disclosure, even though I mounted mine inside the 5er, it is still slightly forward of the trailer axles.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 09-05-2015, 08:21 AM   #14
f5moab's Avatar
Wow, your tireminder system lasted three years?
Mine lasted about 800 miles before I sent them to their deaths in a dumpster somewhere in MT. in that 800 miles, they drove me crazy.
f5moab is offline   Reply With Quote
Old 09-05-2015, 08:29 AM   #15
TST507 here as well. Make sure you get the flow through.
DennisTD is offline   Reply With Quote
Old 09-05-2015, 08:30 AM   #16
gashog's Avatar
I kept my tireminders 3 years and cussed them on every trip.
Sent from my SAMSUNG-SM-G900A using Tapatalk
pressure, tire
