02-04-2019, 12:02 PM
Tire problem?
How concerned should I be? Two of my "China bombs" have developed what looks like "slits". See attached photos. The tires seem otherwise sound. They only have 9500 miles and very good tread left. The one with the small curved "slit" has always needed air added before each trip, but the other one has barely ever needed more than a few pounds if any at all. I keep them at 50 lbs when towing. I have one never used spare and could swap one out...or should I go straight to a Goodyear and get the Endurance? I am currently 2000 miles from home and planned to swap them out when I get back ... in April.
02-04-2019, 12:12 PM
Those tires look aged out or darn close to it. The circumferential crack above it has me more worried. What is the date code stamped on those tires? I'd think those are at least 5-6 years old.
02-04-2019, 12:18 PM
Date is 1114 , so 4 years 2 months. So, I should make a trip to Goodyear soonest?
02-04-2019, 12:25 PM
Can't see the whole tire but on at least one it looks like some curb "bruising" too.
Regardless of age I'd be replacing these tires.
Goodyears would be a good recommendation for you. They have extra rubber "curb guard" molded into their sidewalls
02-04-2019, 12:29 PM
Tire problem?
The cost of new tires is insignificant relative to blow out damage, time in the shop, etc.
Recommend replace immediately. As noted GY endurance is a good choice.
Go up one load range if possible.
We have had 3 blowouts in the last 3 mo. Two of them before the trailer was out of its one year warranty period (<10k mi). Tire company happily paid for replacements but not the damage to the trailer.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
02-04-2019, 12:31 PM
At that age with the cracking that is visible I would be replacing them all.
02-04-2019, 12:35 PM
Also, I check pressures every time before moving the trailer and use a TPMS.
02-04-2019, 01:01 PM
I have a 2016, Replaced castle rocks in 2018. Cracking in tread.
Going into it I told myself new tires every 4 years, regardless if miles on them. Yes I was two years short. Now I cover them when in storage. Between trips in summer and all winter long.
02-04-2019, 01:21 PM
Those tires are a ticking time-bomb. Replace them now to avoid becoming a statistic.
2016 Salem 27RKSS
02-04-2019, 01:42 PM
As mentioned... time for new ones.
My recommendations are Goodyear Endurance, Maxxis 8008 or Carlisle HD.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
02-04-2019, 05:49 PM
Yep, I see age cracking, you will likely have tread separation in the middle of no where. Replace them.
02-04-2019, 06:22 PM
Thanks all. I have an appt. with Goodyear close to where we're currently parked. Saturday we'll have all 4 of them replaced with new E range GY Endurance tires. I just need to make it another 29 miles from campsite to the shop.
02-04-2019, 06:35 PM
29 miles should be no problem. As others have said they are aged out.
In 40 years of trailer towing I have never seen much if any tread wear but at 4-6 years time to replace. Never had a blow out yet, I currently have 16 china bombs on my six trailers.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
02-04-2019, 07:04 PM
Actually, the 11 is the week, not month. The DOT date codes are the week then the year.
If I am doing my math correct, that will make them 5 years old next month.
2011 Flagstaff 831 RLBSS
02-04-2019, 07:40 PM
How concerned should I be? Two of my "China bombs" have developed what looks like "slits". See attached photos. The tires seem otherwise sound. They only have 9500 miles and very good tread left. The one with the small curved "slit" has always needed air added before each trip, but the other one has barely ever needed more than a few pounds if any at all. I keep them at 50 lbs when towing. I have one never used spare and could swap one out...or should I go straight to a Goodyear and get the Endurance? I am currently 2000 miles from home and planned to swap them out when I get back ... in April. Attachment 196154Attachment 196155
Well if you don't get new tires before you leave I'm sure you'll find a place along the way that will help you after your blow out .
02-05-2019, 09:34 AM
Thanks! Now that you say it, I did know that (weeks not months) but have crs ...
02-05-2019, 09:53 AM
but have crs ...
I understand completely. They say that losing your memory is the second sign of old age. I can't remember what the first one is.
02-05-2019, 10:13 AM
Denver To Yuma In 90 Days
Might want to consider replacing the spare as well.
02-05-2019, 07:13 PM
After towing with the Goodyear Endurance. i was so pleassed I replaced the apre with a Goodyear Endurance.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
02-05-2019, 07:37 PM
We just replaced our tires (which turned out to be anywhere from 5 to 9 years old, yikes) with Goodyear Endurance that are one rating up from original equipment, which also have an 87mph speed rating. This was key to the success of our 4000 mile trip from New York to the Florida Keys and back in January. Yes, there are many cheaper tires but I appreciate the speed rating, the extra capacity, and thick sidewall rib. I probably paid about $200 more than the cheapest tires I could find, but I think it was well worth it. Having had a flat on our trip to Maine, which was caused by tire failure, not road hazard, and looking at the others, I knew we had been living on borrowed time.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
