Old 10-22-2015, 11:45 PM   #1
Tanddhall's Avatar
Tire Replacement
I know, another tire question?? I need some new tires for my 2006 Wildwood 22FBS. This is a tandem axle travel trailer with a GVWR 7600 lbs. The last actual towing weight by a CAT scale was about 6400 lbs. I do not have unlimited funds but do want to try and get tires that will give the least amount of problems and when maintained properly less a chance of the "China Syndrome" happening. Current size is 205/75D-15C. Is it worth moving up from a C load range to a D range? Have you seen any major differences using radials versus a bias ply tire? Is tire balancing really important on a travel trailer? Any particular brands of tires stand out as best to use and any brands to avoid at all costs. Any and all feedback is appreciated.
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 10-23-2015, 06:35 AM   #2
wingedone's Avatar
The problems I have seen with ST tires, both on the road, and reading about on forums have been with heavy trailers. Not that it cannot happen with yours, but from what I have seen, much lower chance.
Switching to a D or E rated tire wouldn't hurt.
Balance the tires. The cost is minimal for what could be significant improvement in ride, durability, and safety.
Search this and other RV forums for ST tire recommendations. You will find a ton of discussion. I don't use them anymore, but I have a heavy trailer, so I won't make a recommendation.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 10-23-2015, 07:19 AM   #3
Kenny kustom's Avatar
I'm putting Samson st tires on my sabre.
14 ply. 105 psi.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-23-2015, 10:01 PM   #4
WFD
Going to load range D is a good idea, going to E's on a trailer that weight is overkill. Balancing a very good idea for the little cost..in fact my tire guy was adamant that I have them balanced, and in the end didn't even charge me to do it...
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
replacement, tire
