Old 07-19-2013, 01:46 PM   #1
Tires
On our 2012 Cherokee i have 205/75D14/C Trail Express tires can some one
tell me the speed rating.The camper weighs 3500Lbs empty,there is only
about one thousand miles on the tires.I think by next year i will need new ones,is it better to go to 15 inch &bigger than 205, radial tires or bias ply.
I recently had all 4 balanced there doesent look like a whole bunch of
thread left.We are going camping next week about 200 mile round trip
on the interstate the speed limit is 55 60 65 70 in diffrent spots.
Thank you for any help on this.
2012 Cherokee Grey Wolf
2003 Toyota Tundra
Grey Wolf is offline   Reply With Quote
Old 07-19-2013, 02:00 PM   #2
jtstromsburg's Avatar
Rated to 65mph. I had 14" trail express tires in my old grey wolf also, and had two replaced under warranty with only a couple thousand miles in them. I would look for another brand, and there are plenty of good threads on here on tires. Most seem to like maxxis brand, and I think its much easier to find 15" tires then 14's. If you can afford and are keeping the trailer for more than a year, I say find some good 15" tire/wheels
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-19-2013, 02:03 PM   #3
You probably don't have the room to go to 15 inch tires, and since your camper isn't that heavy, there should be no need to.
If there isn't much tread left on your tires, which is shocking if you only have about a thousand miles on them, get them changed asap. And you may have an alignment issue, so I would have a tire shop check it out to see what they say.
But you should be ok for a 200 mile trip, but no need to rush, so keep the speed down. Not sure what the speed rating would be.
If you check out the Maxxis chart, you will see they have a C-rated tire in your size that will carry 1760 lbs;
http://www.maxxis.com/Repository/Files/m8008load.pdf
Kumho also has good tires. Both are high-speed rated.
bakken is offline   Reply With Quote
Old 07-19-2013, 02:16 PM   #4
Kumho has a 195/14 that has about the same diameter, but can carry 2094 lbs, plus a speed rating of 106 mph.
Old 07-19-2013, 02:19 PM   #5
With only 1000 miles on the trailer and not much tread left, I would be taking it to a shop to have the axles checked for alignment or having bent axles etc. That is very abnormal wear. ST tires (trailer) are rated at 65 mph max.
Good Year Marathons are as good as any and there are dealers all over the US. Others like Maxxis and other brands. I've run GY Marathons on 9 different rv trailers and several racecar trailers and never had a blowout or flat in 38 yrs.
Old 07-19-2013, 02:39 PM   #6
Originally Posted by jtstromsburg View Post
Rated to 65mph.
I think it would be more accurate to say that trailer tires are rated "at" 65 mph, not that they are rated "to" 65 mph. Those ratings are to determine comparable loads at a standard speed.
Kumho has speed ratings of Q and R on their trailer tires, which is for 99 and 106 mph respectively, with obviously reduced load.
Maxxis has stated that their trailer tires are good for 99 mph, or a Q rating.
I asked the guys at Tirerack what Goodyear had to say, and they replied that they wouldn't put a speed rating on them. So I would probably limit them to 65 mph if I had them on my camper.
But I don't drive over 65 mph very often anyway, so am not all that concerned about that particular issue.
Old 07-19-2013, 03:01 PM   #7
According to Maxxis documentation, all their ST tires are 65 mph max.
Size Max speed
ST205/75R14 65
ST205/75R15 65
ST215/75R14 65
ST225/75R15 65
ST175/80R13 65
ST185/80R13 65
ST235/80R16 65
Old 07-19-2013, 03:04 PM   #8
Originally Posted by bakken View Post
...Kumho has speed ratings of Q and R on their trailer tires, which is for 99 and 106 mph respectively, with obviously reduced load.
Actual documentation of these statements?
Old 07-19-2013, 03:16 PM   #9
Fulltime family RVer
Size Max speed
ST205/75R14 65
ST205/75R15 65
ST215/75R14 65
ST225/75R15 65
ST175/80R13 65
ST185/80R13 65
ST235/80R16 65
Yes, but a dealer inquiry indicated differently. Look for a post by wmtire here about a week ago. Essentially, if you are running at less than the max load and inflate against the inflation table for the psi to load, you can increase the psi (without exceeding wheel or tire's maximum cold pressure) to gain an increase in speed rating.
ependydad is online now   Reply With Quote
Old 07-19-2013, 03:24 PM   #10
I read wmtire's post, I was just furnishing Maxxis' own publications.
I know, it's on the internet so it has to be true. Just kidding.
