Old 08-22-2015, 08:51 PM   #11
f5moab's Avatar
Not sure how to measure a "hoot" and a "holler" but Thailand is not China.
And, having been in both countries, quite different.
f5moab is offline   Reply With Quote
Old 08-22-2015, 08:58 PM   #12
bob213's Avatar
If your rims can handle 65lb. PSI the Kumho or Hankook mentioned above would be my first choice. If limited to 50lb. PSI, Maxxis would be my choice. I have both (Kumho and Maxxis on two different trailers) and I am happy with both.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 08-22-2015, 08:59 PM   #13
I think he was talking the Far East, cheap labor.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-22-2015, 09:14 PM   #14
gashog's Avatar
Find the best price on-line for Maxxis M8008 then go to Discount Tires. Get a quote and if it's higher than the on-line price show them that price. They were higher, but then they beat the on-line price once I showed them it. They didn't stock the Maxxis M8008, but only took 2 days for them to get them in... After logging only 2300 miles on my C rated Trail Express, I went to D rated Maxxis and what a difference it made. I used to have a little sway, but with the Maxxis no sway and trailer sure pulls better.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-23-2015, 12:14 AM   #15
bob213's Avatar
Maxxis not available in load range "D" in 14". Still the "C" is a great tire.
Old 08-23-2015, 12:38 AM   #16
mjones12's Avatar
Kumho comes in 14 inch D. Liked the ones I had.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 08-23-2015, 12:42 AM   #17
bob213's Avatar
Did you run them at 65PSI on your Surveyor rims without any problems? I was hesitant as that is a 30% overload on the "stated" rim capacity. Don't really believe you can blow out a rim???
Old 08-23-2015, 03:52 AM   #18
sail2liv's Avatar
Almost anybrand is okay, some better.....but the best thing is to follow complete tire care and inflation and speed recommendations....when you exceed speed of tire sidewall breaks down, when you do not inflate correctly either moving or sitting sidewall breaks down, uv breaks side wall down....make sure tire date is within 6 months of purchase date...or less....good luck only load ST to 85% if inflated to max
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 08-23-2015, 07:59 AM   #19
mjones12's Avatar
No, I had the Kumhos back in 2004 on a Casita, which came standard with Marathons, 14-inch C. Many on the Casita forum were switching because of so many blowouts with the Goodyears (which I think was mostly because of overloading).
They were saying at the time that unless the rims were marked otherwise, the 60 psi would not be a problem. I'm not sure what the Surveyor rims say, but I was told back in 2004 that you had to take the tires off to find out.
Old 08-23-2015, 08:38 AM   #20
muddyrode's Avatar
I have the stock tire on my wildcat but i did have them balanced and steel vavle stems. Put in And have never had a problem (knock on wood) but i chane i,m going to go with carlisle tires
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
tire, tires
