Old 06-06-2011, 10:21 AM   #1
Tires P vs LT - My Experiences
I just thought I would post our findings for people thinking of changing from P rated tires to LT rated tires. ;-)
Our Expedition EL came with P rated tires and we towed our trailer with them for the latter part of the summer and fall last year and for one trip this year. The truck handled OK with these tires and after doing a lot of research, I was not sure if I really would like to go with LT tires. Some people stated they rode too rough, or some were too loud, etc. I was forced to make a decision, even though my tires were not worn, they all had a servere case of dry rot (that is a whole different story, Pirelli are you listening? grrrr...) .
Anyhoo, I contacted the good people at Toyo, gave them all the specs on the vehicle and trailer and they recommended that we go with their Open Country A/T series LT tires with a load rating E - 10 ply. I put a set on Friday and could immediately notice the difference in the ride, for the better. We hooked up to the trailer and went away this weekend and to say the difference was like night and day would be an understatement. There is a really good dip on the one highway we travelled on and with the old P tires, the vehicle would bounce up and down a few times after such a dip and just not feel the best. With the new tires, the vehicle bounced once just a wee bit and felt super stable. The truck also felt way better driving through curves and such. If you do a sudden lane change, or yank the wheel from left to right in a swerve, it no longer feels like the tires are rolling over, body roll is pretty much eliminiated and again it is extremely stable. As for the ride, our Expedition used to feel like it was floating down the highway in everyday driving, very smooth. With the new tires, it is a bit rougher, but only a bit, my wife said she could hardly tell the difference when driving, road noise is also very very minimal. It is still early days for everyday driving, however I will never be going back to a P tire or anything less than a 10 ply.
So for anyone thinking of making the switch or looking at improving the drive and safety, I would say go for it, you will not regret it! Just my two cents
Best Wishes,
Chuck
2010 Ford Expedition EL 4x4
2011 Prime Time Tracer 3150BHD
1 Lovely Wife
3 Energetic Wee Boys
flumpydog is offline   Reply With Quote
Old 06-06-2011, 11:36 AM   #2
Triguy's Avatar
Agreed. I will never have a P-rated tire on my SUV again either. LT is the way to go. E's would shake out my fillings so I have LT-C tires and they work well for me.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-06-2011, 12:35 PM   #3
I was not so sure about the E's but Toyo stated you can try them out for 30 days and if you do not like them, you can return them here in Canada, so I figured I could not go wrong. Surprisingly I am not finding these to be too bad thus far in everyday driving. Agreed on the never using P tires again
Old 06-06-2011, 03:35 PM   #4
Wanna Be Camper
SaskCampers's Avatar
Toyo /Nitto are probably the best LT tires out there. Especially on a Dodge as they have very stiff sidewall's.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 06-06-2011, 08:18 PM   #5
flyrotor's Avatar
The noise is not related to the LT or E rating, rather the type of the tread, street tread is quiet, AT create a bit more noise, Mud and Snow even louder. P tires are for just what they are - Passenger tires, whenever putting any load whether towing or directly on the axle they are too soft
flyrotor is offline   Reply With Quote
Old 06-06-2011, 09:43 PM   #6
I agree 100 percent. I put LT 265 70 17"s on my Ram 1500, and it also made one heck of a difference towing! Side to side sway was virtually eliminated, due to the 10 ply's stiffer sidewalls, and my tires are quiet- no noticable noise whatsoever. Highly recommended for anybody towing a camper 26 feet or more, and my ride quality seems as good as it was with P tires, when they were properly inflated. I'm running 50 psi in mine. They can hold 80 max cold. The ONLY drawback is they are more costly, due to more material used in their construction. I'll pay the difference again, no problem! Randy
Old 06-06-2011, 10:38 PM   #7
leencharlotte's Avatar
Question based on this topic. I have a Tundra crewmax with p-rated tires. Though the tires are 2800# rated I can feel some "slop" at certain points when towing. It is not really sway, more of a jiggle, actually feels more like the trailer is rocking side to side. Of coarse the TRD offroad pkg Blistien shocks are probably not helping either. The truck is 9 months old, 8k miles
So my question is what is I just replaced the rear tires now and wait til my fronts wear a little more? I am really having a tough time dropping $1k on 4 new tires when the tires I have are pretty much new. Anyone done this method?
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 06-07-2011, 12:04 AM   #8
flyrotor's Avatar
I can't say for sure, but often times mixing tires is not recommended, for sure true with bias vs radials, but ask your tire store, or you can google tirerack with the question, they have a pretty good FAQ list that probably already addresses the issue
Old 06-07-2011, 05:12 AM   #9
"P" tires came from the factory on my Heavy Duty 1/2 ton and they tow well, but when they wear out i will go to LT's just for GP.
Old 06-07-2011, 06:48 AM   #10
Triguy's Avatar
I wouldn't do it except in an emergency. You can opt to buy two new tires similar to what you have and from from the same class of tire but its not recommended that you mix tires from an alternative class (P and LT, etc). That will make the handling worse; not better.
The common rule is to replace all 4 tires when possible. Sometimes this is not possible because two wore out faster for some reason. Than you can buy two new tires and put them on the rear but these tires should be the same tire or at least similar as you currently have.
I would continue to ride with my old tires until they wear down and save for the tires you want.
Scott
2012 Shamrock 233S
