Old 09-07-2016, 02:33 PM   #11
RollingDownTheHighway's Avatar
I live in CT with the snow, ice, leaves, rain, etc. and never cover ours and it's sits next to the house right out my fam room window. We put fabric sheets in it after our last trip for the winter, and never had any issues with mice, ants, etc. when we open it up in the spring.
2013 Prime Time Tracer 3200BHT
2016 GMC Crew Cab Duramax All Terrain
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 09-07-2016, 02:56 PM   #12
ilmor's Avatar
I vote for covering it. I live in the NE and have always covered my RVs late Sept. thru April. My 2010 Solera looked new when I traded it a couple of months ago. Just think, you are protecting your RV from UV, the most damaging thing, for much of the year. Cover your tires too.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-07-2016, 04:00 PM   #13
I live in northern Canada , this will be my fourth year with my cover. We get lots of snow, ice, and wind. I wouldn't think of not using a cover, unless I was parked inside. In the spring, just a quick rinse and good to go. Don't buy a cheap cover though, you get what you pay for with these things for sure.
Leprechauner is offline   Reply With Quote
Old 09-07-2016, 05:37 PM   #14
ARLO
40 years many trailers, never covered any. No problems.
rlocicero is online now   Reply With Quote
Old 09-07-2016, 06:35 PM   #15
You will avoid ultra violet exposure , which will reduce fading , and prolong the life of your seals. The bonus is , it's nice and clean when you in cover in the spring.
Old 09-07-2016, 07:43 PM   #16
WFD
In northern climates UV is a non factor from late fall to spring.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-07-2016, 07:54 PM   #17
Georgia Frog Rally 2017
aceinspp's Avatar
Cover it. Protects camper and helps prevent water intrusion should you caulking start to give out. I do it every year at seasons end. Looks good when you un cover at beginning of new season. I use Adeco cover and works very well. You can secure it to prevent rips and tears if done right. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 09-07-2016, 09:09 PM   #18
I'm not sure where you live but, it can get to -40 degrees here with the sun shining bright. There is still a UV factor.
Old 09-07-2016, 10:06 PM   #19
WFD
Check with Environment Canada what your UV Factor will be in the dead of winter when it's -40...sure the sun shines bright, but the UV factor at that time of year is pretty much non existent....it's like people insisting wind chill effects surfaces other than skin.
Old 09-07-2016, 10:22 PM   #20
So, your point is?
cover
