09-06-2016, 07:43 PM
To cover or not cover???
Ok I live in southern wv. I have a 2015 267bhsk. We get snow and cold weather in the winter. Some days are down to below 0. A lot of 20-38. My question is should I start covering up my camper? This is my 3 winter with it and I never have. Just wandering should I do it or not. I have heard good and bad about it. Just needing and wanting some other people's opinions. Thanks
1014 1500 GMC
2015 solaire 267bhsk
09-06-2016, 08:03 PM
I live a lot further north, get lots of snow, ice. I don't as the wind would either rub the surface off or tear the cover into pieces. I don't see my trailer everyday.
If you are parked under trees and can secure or see the trailer to check the cover I would say go ahead.
B and B
09-06-2016, 08:14 PM
That's exactly what you will hear good and bad.............
The only cover I would use is a metal carport or building. 30 years of camping one cover lasted 6 months windy here, never another. We are about an hour south of Roanoke VA.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-06-2016, 08:33 PM
I agree with the other 2 posts....I also live further north than you and we get snow in Nov and it stays with us till spring melt. I have never covered either and seen many who have who have suffered more damage by covering. Wind will be your worst enemy, and along with wind comes dust particles than can get lodged under your cover and the constant wind will cause some movement. Ours needs a good wash in the spring, gets a good waxing before onset of winter, and in spring is just fine.
Some people swear by their covers but I think factors to consider are wind where you live and humidity levels. Some have to be concerned about sunlight but in winter in northern climates UV rays are not a factor. With regards to snow load...our trailer is stored in a very open area in winter and I check up on it a few times over the winter and the amount of snow on it is minimal. For some reason it just seems to blow off.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
09-07-2016, 12:46 PM
cover or not
Plastic tarps, grommets and bungee cord hooks can cause damage in windy areas. Nylon covers that are taylored for your rv are much better but cost more. Used a plastic tarp for a few years with popup and tt and did a little cosmetic damage. We are in mid Michigan near the lake and it seems always windy. Used a canvas car port for a few years. That worked great until the township told us we had to take it down. Now we use in-laws barn which is the best if you have indoor storage available to you.
09-07-2016, 12:49 PM
I live in the metro area of St. Louis, and I use a breathable cover during the harshest months. Important to have it snugly attached via the undercarriage or damage could occur. Knock on wood, but no problems yet. Covers do keep it cleaner and offer a little protection from the elements.
Belleville Bob
09-07-2016, 12:55 PM
Cover it. Its the UV rays that ruin a rubber roof, not snow or rain. Covering your rig adds years to the life of your roof. Use a good quality cover that allows air flow through it. If you use a tarp, just be sure the res lots of ventilation under it or you' I'm end up with mold and mildew on it and thats not good either.
09-07-2016, 01:19 PM
Rv cover
I had mice and moles build nests between the cover and the roof of mine and thank god the ate up through the cover and not down into my rubber roof!!
They climbed up in between the wall and cover so no more covering for me.
09-07-2016, 01:25 PM
I also use a cover but I don't have a choice, the FL sun destroys anything in it's path. Haven't had any problems with damage from the cover. Sunbrella is the best fabric made for covers. See my review for Goldline covers in the product review section.
09-07-2016, 01:31 PM
Cover
I cover mine, living here in Arizona the sun eats up everything. Would rather replace a cover every few years than a roof.
09-07-2016, 01:33 PM
I live in CT with the snow, ice, leaves, rain, etc. and never cover ours and it's sits next to the house right out my fam room window. We put fabric sheets in it after our last trip for the winter, and never had any issues with mice, ants, etc. when we open it up in the spring.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
09-07-2016, 01:56 PM
I vote for covering it. I live in the NE and have always covered my RVs late Sept. thru April. My 2010 Solera looked new when I traded it a couple of months ago. Just think, you are protecting your RV from UV, the most damaging thing, for much of the year. Cover your tires too.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
09-07-2016, 03:00 PM
I live in northern Canada , this will be my fourth year with my cover. We get lots of snow, ice, and wind. I wouldn't think of not using a cover, unless I was parked inside. In the spring, just a quick rinse and good to go. Don't buy a cheap cover though, you get what you pay for with these things for sure.
09-07-2016, 04:37 PM
ARLO
40 years many trailers, never covered any. No problems.
09-07-2016, 05:35 PM
You will avoid ultra violet exposure , which will reduce fading , and prolong the life of your seals. The bonus is , it's nice and clean when you in cover in the spring.
09-07-2016, 06:43 PM
In northern climates UV is a non factor from late fall to spring.
09-07-2016, 06:54 PM
Georgia Rally Coordinator
Cover it. Protects camper and helps prevent water intrusion should you caulking start to give out. I do it every year at seasons end. Looks good when you un cover at beginning of new season. I use Adeco cover and works very well. You can secure it to prevent rips and tears if done right. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-07-2016, 08:09 PM
I'm not sure where you live but, it can get to -40 degrees here with the sun shining bright. There is still a UV factor.
09-07-2016, 09:06 PM
Check with Environment Canada what your UV Factor will be in the dead of winter when it's -40...sure the sun shines bright, but the UV factor at that time of year is pretty much non existent....it's like people insisting wind chill effects surfaces other than skin.
09-07-2016, 09:22 PM
So, your point is?
