07-26-2017, 03:26 PM
Retired
To drain water system or no to drain
Our last trip with the Windjammer was the first of May and unfortunately it has been sitting in the yard since then. Question...should I drain the H2O system including hot water heater? The fresh water tank is empty. At this time not sure when our next trip will be.
Thanks for the feed back.
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
07-26-2017, 03:31 PM
Yes drain the system.
07-26-2017, 03:52 PM
Retired
it's DONE...thanks
2017 Columbus 340RK
07-26-2017, 04:15 PM
Kasual Kamper
Unless you're concerned about the quality of the water from your last trip, I don't worry about water sitting in the system for months because it's minimal... mostly the 6 gals in the hot water tank. I don't think water goes "bad". The next trip, most of the water gets flushed through anyway.
The only time I purge the system completely is at the end of the season.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
07-26-2017, 04:31 PM
Don't think water goes bad? Put a jug of tap water in the sun for 2 months. Would you drink it?
Yes, it goes bad, Drain the system.
2015 F-250 FX4
07-26-2017, 06:19 PM
I always drain beginning of winter as per winterizing procedure. In season between trips I only drain and refill if it has been in the tank for a month or so. Sometimes I bleach and rinse if it has been in there too long and at the beginning of each camping season.
07-26-2017, 07:27 PM
Is there a way to drain the water heater short of pulling the anode rod?
07-26-2017, 07:30 PM
Pull the anode rod is the only way on any water heater I've seen. I would flush the water heater instead of draining it. Just run the pump or city water thru it for 10 mins or so. I only drain the water heater when I winterize.
A couple of times a year I drain the fresh tank and re-fill and add half cup bleach.
07-26-2017, 07:44 PM
Open low point drains, open relief valve on water heater, open hot and cold valve on a fixture. Walk away. That's what I do after every trip. It take 2 1/2 minutes.
07-26-2017, 08:10 PM
Good way to go.
07-27-2017, 01:38 PM
AKA: 'tiredTeacher
Especially if it's well water and not treated, municipal water. If I've been on well water at a CG, I drain it when I get home.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
07-27-2017, 01:57 PM
Bacteria growth is the prime concern especially in warm moist holding tanks. (Bleach the system once or twice a year.) That's why we never drink the water. We always carry our own bottled water just for drinking.
2018 Berkshire 38A
07-27-2017, 03:22 PM
Boondocking Only
Yes, drain it.
Yes water goes bad, quicker than you think.
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
07-27-2017, 04:48 PM
Agreed, just check Springwater it has an expiration date.
07-27-2017, 05:13 PM
LOL...because they want you to buy more!
I bet people would get upset if there wasn't one.
07-27-2017, 05:22 PM
I always drain at least the HW tank. One year my camper was not used for 2 months during very hot weather. The trailer developed a rotten egg smell . I am guessing It was stagnant water, it took a lot of cleaning the system with bleach to destroy the smell. My thinking the HW heater is a closed unit and did not think it would be contaminated. Really don't know if that was the problem but since I started draining the system I have had no more smells.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
07-27-2017, 08:29 PM
I'll have to give that a try, I don't think water goes bad unless there was something else in the jug to start with.
07-28-2017, 12:05 PM
I don't bother draining our water system between trips, first of all how may of your drink hot water coming out of the heater. Second, if you think the water in the pipes has gone bad, just turn the hot and cold water taps on and allow them to flush out the old water, this is much easier than crawling under your RV and opening and closing those drain valves.
07-28-2017, 01:32 PM
Correct...you aren't supposed to drink or use for cooking the water that comes through the hot water system even at home. That is because of the anode.
