Old 04-12-2016, 12:34 PM   #11
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by Ford Idaho View Post
I have been using this.
Works well as a lube and does not seem to attract a lot of dirt, I also use it on the seals and stab jacks.
This!
Slideout, seals, stab jacks, squeaky doors, steps, hinges....pretty much everything that moves! and a little goes a long way!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 04-12-2016, 07:20 PM   #12
CDR USN Ret
Originally Posted by rollingroo View Post
When we opened our slide for the first time this year it was grinding louder than normal .we went to the dealer today to buy some slide grease. The dealer said do not grease the gears it only attracts dirt. They suggested just wipe with a cloth or blow with an air compressor to remove any grit. Any thoughts on this?
Lippert?
Hydraulic or Electric?
Lippert Master Towable Manual (Googleable):
hydraulic - "moving pats. They can be washed with mild soap and water. No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system."
electric - "Note: Do not lubricate rack or pinion gear teeth, lubricate drive shaft only. Note: LCI recommends Mobile One Fully Synthetic 10W-30 Motor Oil to lubricate gear pack."
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 04-12-2016, 08:47 PM   #13
I agree with exactly your logic. I grease mine too..
Jordyn is offline   Reply With Quote
Old 04-13-2016, 07:31 AM   #14
Walmart sells this much cheaper and everyone has a Walmart
selkirk awards is offline   Reply With Quote
Old 04-14-2016, 08:14 AM   #15
Wolverine 1945's Avatar
I think the Slide Co. recommend a lub with PDF for the inside gears,,, I found a White Lithium Grease with PDF @ Menards last year !!! Try Goggling how to lub Slides ???
I think there is a video on UTUBE ???
Wolverine 1945 is offline   Reply With Quote
