04-11-2016, 04:08 PM
To grease or not to grease
When we opened our slide for the first time this year it was grinding louder than normal .we went to the dealer today to buy some slide grease. The dealer said do not grease the gears it only attracts dirt. They suggested just wipe with a cloth or blow with an air compressor to remove any grit. Any thoughts on this?
04-11-2016, 04:13 PM
I grease mine. They are enclosed while traveling and are under the slide when extended, how much "dirt" are you going to get under there? They seen to slide in and out better with some grease on them. Just my opinion.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
04-11-2016, 04:16 PM
I have been using this.
Works well as a lube and does not seem to attract a lot of dirt, I also use it on the seals and stab jacks.
04-11-2016, 05:05 PM
Related: my slideout made grinding noises but turned out the noise was coming from the slide awning. Shots of WD40 at either end of the roller fixed it.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
04-11-2016, 05:58 PM
Thanks we just picked some up and will give it a try.
04-11-2016, 09:48 PM
Graffite works great.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
04-11-2016, 09:53 PM
X3 on Silicone Spray with Graphite. Does the best of both worlds.
B and B
04-11-2016, 10:02 PM
Left Coast
Dry lube in spray form
04-12-2016, 12:16 PM
Canadian Member
X2
04-12-2016, 12:34 PM
i talked to a lippert tech he said they use CRC dry lubricant and that what he recommended on the slide out rails
and while at wally world the other day i saw that liquid wrench now has an RV dry lube in the RV section
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
(Dry Huunday)
This!
Slideout, seals, stab jacks, squeaky doors, steps, hinges....pretty much everything that moves! and a little goes a long way!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
04-12-2016, 07:20 PM
CDR USN Ret
Lippert?
Hydraulic or Electric?
Lippert Master Towable Manual (Googleable):
hydraulic - "moving pats. They can be washed with mild soap and water. No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system."
electric - "Note: Do not lubricate rack or pinion gear teeth, lubricate drive shaft only. Note: LCI recommends Mobile One Fully Synthetic 10W-30 Motor Oil to lubricate gear pack."
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
04-12-2016, 08:47 PM
I agree with exactly your logic. I grease mine too..
04-13-2016, 07:31 AM
Walmart sells this much cheaper and everyone has a Walmart
04-14-2016, 08:14 AM
I think the Slide Co. recommend a lub with PDF for the inside gears,,, I found a White Lithium Grease with PDF @ Menards last year !!! Try Goggling how to lub Slides ???
I think there is a video on UTUBE ???
