Old 05-24-2015, 10:56 AM   #11
We have the same set up iin our Heritage Glen- same model. True on manual being no help. The dealer we got it from did explain it to us. It is used-turned when not hooked up to city water using water from tank
seicken is offline   Reply With Quote
Old 05-24-2015, 11:16 AM   #12
Originally Posted by captnrick3 View Post
...The rod will usually consume itself in 12 to 18 months depending how much you are connected to shore power (which creates electrolysis)...
What does shore power have to do with the water heater anode being consumed?
The anode will be consumed as long as there is water in the water heater regardless of whether the shore power is connected or not.
Old 05-26-2015, 09:45 PM   #13
captnrick3's Avatar
Shore power intensifies the effects of electrolysis in many rigs due to poor grounds etc. Same issue as power boats in the ocean plugged in to shore power. Any AC power source around water increases galvanic action.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-27-2015, 07:52 PM   #14
We all knew which valve you meant the first time, but the issue is you still need to look behind the panel to determine what it goes to, to many choices, or even could be a repair from a tech or owner??
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 05-27-2015, 08:13 PM   #15
In mine this valve closes the line to the water heater to be used while winterizing. If you use pink rv antifreeze and do not close the valve, you water heater will fill up and use more of the pink stuff.
2013 Sierra 346 RET
2010 Ford 350 6.4 l CC SRW
ksignoles is offline   Reply With Quote
Old 06-04-2015, 08:52 PM   #16
JnJ in TX
Still Valvin'
Originally Posted by 05CrewDually View Post
I believe that is a water heater by - pass for winterizing. You don't want to waste putting gallons of antifreeze in your water heater.
Is this what you're referring to:
Attachment 77818
Yes. When connected to city water, if I closed the valve, the water pressure inside seemed to increase. It's still a mystery to me.
Thanks for all the responses. I wish there was more (any) documentation on this... The hose to the left of the valve is for winterization. I have it pushed back into the storage box behind.
JoandJames is offline   Reply With Quote
Old 06-04-2015, 09:06 PM   #17
JnJ in TX
New RV Friends
Originally Posted by Tiggerdad View Post
Welcome to the forum. I see your city and state. Same as mine. Live past Junior High in L.C.-M.
Traveling now. Will be back in town towards the end of the week. I will contact you and willing to help you learn the "ropes."
It's a small world. We are in Bear Trails.
Old 06-05-2015, 05:40 PM   #18
To Valve or not to valve
It's the shutoff from the fresh tank. Use it to Winterize. Drain the fresh tank, close that valve, then you use the Winterize hose into antifreeze. This valve keeps the pump from pulling from the fresh tank and forces it to pull from the siphon hose (bottom center of picture-pull hose out, remove cap and stick in gallon jug). I have the same setup. It will not fill the fresh from the city water connection. Valve has to be open to pump water from fresh tank. Otherwise, it can stay closed all the time. , . Click image for larger version
Name:	ImageUploadedByForest River Forums1433544027.400131.jpg
Maxhise is offline   Reply With Quote
Old 06-05-2015, 06:15 PM   #19
Just remember they can't both be open at the same time. If you remove the cap, the pump will suck air and if you leave the valve open, the pump will not suck antifreeze.
